Toyota Prius Freon Leak at Shrader Valve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rspiet, Jul 29, 2015.
  1. rspiet
    rspiet Junior Member
    Highland, IN
    Four Touring
    I had my a/c recharged in April and it was blowing hot again by July. I brought it back in today and they told me that it is leaking out of the Schrader valve on the low pressure side. They told me that they would have to replace the entire line which would cost a few hundred just in parts. Why can't they just replace the valve. The tried calling auto stores for a special part, but could not find one. Any advice on how to seal or repair just the leaking Schrader valve and not the entire line?
    52,862
    is this a dealer or a/c shoppe?
  3. rspiet
    Highland, IN
    Four Touring
    Toyota dealer in Schererville, IN.
    52,862
    how about something from a salvage yard?
  5. JTM2955
    JTM2955 Active Member
    475
    185
    It can be "replaced". It just screws in, and yes they can be turned in with a special longer version of the Schrader valve tool.
    I will bet that when the tech unscrewed the low side hose, it turned the valve open.
    It's amazing it lasted this long. Those are some great valve caps.
    LG-D851 ?
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    if they did try to tighten the valve core (which an honest tech would do) and it still leaks, the core should be replaceable. if the seat for the core is damaged somehow, then the line would need replacing. but I would call a local independent parts store that doesn't suck if you have one, and see if they can get a Schrader valve core. the dealer might just be trying to hose you if all you need is a screw in valve core.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    Sometimes you can get a sealing cap.
  8. JTM2955
    475
    185
    If it has lasted this long, then it has tobe one tiny leak.
    LG-D851 ?
  9. rspiet
    Highland, IN
    Four Touring
    Thanks for the replies.I will try to find a Schrader Valve Core.
