Toyota prius gen 3 proper engine startup warm up
Discussion in 'Gen 3 Prius Main Forum' started by Anas Almustafa, Jun 13, 2015.
  1. Anas Almustafa
    74
    28
    Arbela, Irbid, Jordan
    I have noticed that the gasoline engine starts running when i first start my prius for a while without an indication on the MPG indicator that its running then it stops by itself shortly after startup.
    I assumed that its warming up. Is this the total warmup cycle for the prius proper startup ?
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It's only warmup for the cat. converter. The engine warmup continues as you drive. There are several "stages" it goes through before it's completely finished the warmup procedure. If you search on this forum you will find the warmup stage description.
  3. Anas Almustafa
    74
    28
    Thank you, i'll search for it
    So this is the only warm up needed before starting to drive right ?
  4. David Beale
    5,963
    1,989
    Edmonton Alberta
    You don't really need to let it warm up at all before driving. Just be gentle for the first half minute or so. This is usually easy as most of us have to drive down back lanes etc. before getting to higher speed roads.
  5. bisco
    52,350
    what is the temperature range in your area?
  6. Anas Almustafa
    74
    28
    Temperature range is around Summer: 20 to 40 C
    Winter: -5 to 25 C
  7. bisco
    52,350
    20 still requires quite a bit of warmup and 40 should only take a minute. but with the engine requiring a minimum higher than that, it will still need to run now and then to maintain and of course at start up.
    Anas Almustafa likes this.
  8. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
  9. Anas Almustafa
    74
    28
  10. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I asked a Honda service advisor recently, "How long should I wait to start driving after starting an engine?"
    His answer: You are safe to start driving as soon as there is normal oil pressure in the engine. Does that make sense, gearheads out there?
  11. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Yes engine in traditional car would wear very fast if you would drive (use the torque of engine) when there isn’t oil pressure. Luckily it should only take 0.1…5 seconds for oil pressure to build depending on engine, oil, and temperature. Engine will still wear faster than normal after this. Engine will wear faster than normal if engine is not in normal operating temperature.
    In a Prius computer tries to minimize the engine wear when it can. So only thing that should be avoided with cold engine is fast acceleration especially on steep hills and low hv-battery. If my engine temp is bellow 40c (104F) I accelerate and drive uphill’s slowly especially if hv-battery is bellow 4-bars.
    m.wynn likes this.
  12. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    Oops, I did this today.
    I had a funny feeling this wasn't a good idea. I think maybe the engine sounded different or responded differently.
    What may have been the impact on the engine?
    #12 PriusNeckBeard, Jan 28, 2017
  13. Mendel Leisk
    41,860
    Minor, otherwise the roads would be awash with "broken" cars. But it's good to avoid.
    PriusNeckBeard likes this.
  14. PriusNeckBeard
    376
    211
    Cincinnati
    Thx Mendel.
