toyota prius jack does not come with wheel chock
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by andy post, Sep 12, 2012.
  1. andy post
    andy post Junior Member
    Why does the jack that is supplied as an accessory not come with a wheel chock. It is quite dangerous to jack up the vehicle without wheel chocks under most conditions. so, why is it not included?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I have never owned a car that included a wheel chock that came with jack. That includes GM, Ford, Chrysler, Honda and Toyota. Have you?
    If you need a wheel chock they are readily available.
  3. Mike500
    Mike500 Senior Member
    2,593
    764
    Want one? Just go to your local Walmart and pick one up for $3.24 plus tax. That's whrer I got mine.
    If Toyota supplied one, you can bet that it would increase the MSRP of the car by at least $15 or even more.
  4. andy post
    sure, this is not a complaint against toyota or prius. just that I think it should be included. the tools go hand in hand i think. it doesn't make sense to provide one and not the other.
  5. bisco
    49,490
    don't give them any ideas. they might leave out the jack.
    Mendel Leisk and anewhouse like this.
  6. andy post
    bisco ... Ha! Ha! they might do that!
    Anyway, I bring this topic up because I was unfortunate to have the car roll while jacked up (mind you, the car was on flat surface). Realized the importance of wheel chocks!
  7. andy post
    ofcourse now I am going to do that and invest in some good chocks but the point is for the millions of car owners out there, it is important to tell them not to use the jack without chocks and they should go out and buy a couple. Even the owner's manual does not mention the use of chocks.
  8. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    If your car (Prius) is in park and you raise the rear you should not have any movement and likewise if the parking brake is set and you raise the front you should be fine there also. My 1993 GMC Sonoma pickup has wheel chocks in its tire changing kit.
  9. Mike500
    2,593
    764
    I have the Race Ramp chocks, as well as the cheap yellow Walmart ones.
    The Race Ramp chocks weigh nearly 5 pounds each, while the yellow plastic one weighs 5 ounces. I carry the yellow one in my car.
  10. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    One car I owned came with one metal wheel chock - my 1991 BMW 318i. I kept the chock after the car died with 199 K miles, but lost it over the years. It was a great accessory for using the jack.
  11. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    all,
    Our Nissans used to come with a collapsible metal one included in the lug wrench pouch (worked well). I should have held on to a couple of them [no Nissans for us since about 1990---4 Ford Escorts, 1 Dodge Caravan, 1 Mazda (all used) & then the 2005 Prius (new)].
    Ken (in Bolton,Ct)
  12. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    I seem to recall in my prius v manual which i finished reading about a week ago that it does in fact reccomend using wheel chocks when jacking up the car to change a flat tire. Also shows a picture with those wheel chocks in place. Can't remember which page it was on, my manual is at home and i am at work.
  13. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Put the parking brake on good and hard and don't lift both rear wheels off the ground at the same time. Problem solved.
    Mendel Leisk and dustoff003 like this.
  14. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I realize that this is an ancient thread, but whilst I think that yours is an admirable idea, I really think you'd do better by hollering "…just use yer COMMON SENSE folks!" …and good luck with that too!!! ;)
  15. bisco
    49,490
    i purchased a blackboard, no chalk with that either.(n)
    WilDavis likes this.
  16. WilDavis
    2,492
    2,153
    49
    …doncha just hate it when that happens?:eek:
  17. bisco
    49,490
    yup, had to use my fingernails.:sick:
  18. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Just use a rock. And when I say a rock, I mean a ROCK.
  19. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    My Toyota jack didn't come with a wheel. I'll forgive Toyota for not including a wheel chock if they give me a spare wheel. Not sure what an emergency jack is doing in my car without a spare tire. Why would I ever need it?
  20. Mendel Leisk
    38,726
