Toyota Prius Red Triangle light and headlight icon
Discussion in 'Gen 2 Prius Technical Discussion' started by Mike Hunter, Jan 5, 2016.
  1. Mike Hunter
    Mike Hunter New Member
    Maryland
    My Toyota prius 2006 get red triangle light appears when I start the engine and it disappears when I drive the car. When I stop the car, it comes back again. The warning light is like in the picture I attached. Please help me with this issue.
    Thanks
    Mike
    51,155
    how many mile on her?
  3. Mike Hunter
    Maryland
    150k
    51,155
    do you have the headlight leveling system?
  5. flxcon
    flxcon Junior Member
    16
    los angeles
    This is an easy fix. It is no even a problem. Hatch in trunk doesn't closed all the way. That is the problem. You will see it more when turning and going down.
  6. Mike Hunter
    Maryland
    I do not have the headlight leveling system.
  7. Mike Hunter
    Maryland
    I just checked it and I closed the trunk all the way and the light was still on.
  8. bisco
    51,155
    until someone else responds, i'm going to have to go with pulling the codes.
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Agreed. Get the codes read and report back. Many auto parts stores will read the codes for free.
    Or else go to a local independent hybrid mechanic.
