Toyota Prius Touring 2009 vs 2010
Discussion in 'Gen 2 Prius Main Forum' started by Joe Wall, Jan 8, 2019.
  1. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    I found a pretty decent deal on a 2009 Toyota Prius for $7900 with 66,000 miles. What are the pros and cons to the Toyota Prius Touring 2009? The 2010 would be nicer due to the MPG but would have about 100,000 miles for $8000.
    Any advice? Any issues with either of these vehicles?
  2. JC91006
    16,487
    8,401
    Do you know what a touring model has on it? 2009 has a smaller 1.5liter engine. 2010 has 1.8 liter
  3. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    I know it has a backup camera. Do you want to know the generation of the Touring?
  4. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    I would need to check on what is exactly on it. I can call tomorrow and followup.
  5. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Biggest issue with the 2009 would be lack of battery exercise. Less miles is not always more with a hybrid.
  6. bisco
    49,522
    welcome!
    2009 is a nice year. you can put 15" wheels on if you want better mpg's. 2010 mpg's won't be better and they have a lot of problems.
    both cars are old and susceptible to expensive repairs, especially if you don't diy.
    all the best!(y)
  7. Tideland Prius
    16,159
    The 2009 Touring models have HIDs which have been problematic compared to the halogens on the Gen 2. The 2010 has an engine oil consumption potential after 100,000 miles (I just crossed that so I haven’t seen it yet but you can search the forums for those who are well past 100,000 miles).
    The 2009 is bulletproof (except for the HID) and is likely to be very reliable. The 2010 has a bit more power, better mpg and a smooth engine on/off shutdown.
    I guess do you wanna deal with headlight problems or engine problems. Both hybrid systems are reliable.
  8. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    I chose the 2009 because of the engine problems. Any suggestions to increase the MPG? I'm getting 37.9 in the winter. They advertised at like 45 to 48.
  9. Tideland Prius
    16,159
    Use an engine block heater to preheat the engine. It’s more efficient to use electricity to preheat the engine block than to use gasoline (especially since the Prius engine is efficient which means it creates less heat byproduct).
    Below 32°F, block the lower air dam with foam pipe insulation (do a search for blocking grille or foam pipe insulation).
    In really cold temps (e.g. below -5 or -10°F), block half of the upper grille).
    Ensure your tire pressures are inflated. You lose 1 psi per 9°F drop.
    FireLawdZuko and srellim234 like this.
  10. wild desert
    wild desert New Member
    Why do 15" wheels give better mpg than 16" wheels?
    #10 wild desert, Mar 24, 2024
  11. bisco
    49,522
    it has something to do with 'sprung weight' i think? not an expert, just what i've read here
