Toyota prius vibration
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ifty1989, Feb 21, 2019.
  1. ifty1989
    ifty1989 Junior Member
    england
    2014 Prius c
    Excel
    2014 prius the car vibrates whilst driving. Doesn't happen all the time been told it's the spark plugs that been changed but it is still vibrating. Anyone else experienced this??
    Patricia Morgan likes this.
  2. 09Prius2
    09Prius2 Member
    201
    88
    FL
    Engine vibrates? Wheels/tires vibrate?
    The engine cycle on and off so you should easily be able to tell what is vibrating.
    CoolPrius and audiodave like this.
  3. Patricia Morgan
    Patricia Morgan New Member
    sT. lOUIS
    Hi- I have had this problem for the last 2 years. It recently got worse; I found out that it was a right-side caliper which was causing the brake pad to brake, when I was not braking. This caused the right brake pad to be further worn than the left; perhaps you could take a look at your brake pads and see if they are evenly worn. It took so long for me to get a proper diagnosis, as the problem would come and go; by the time I could get it to a shop, the problem would go away! best of luck!
    (I have to get new rotors, brakes, brake pads, brake hoses and calipers)
  4. ifty1989
    england
    2014 Prius c
    Excel
    It's been checked over yesterday. They changed the spark plugs again. And it's cured it slightly. U can still feel it slightly jerking. Brake pads are evenly worn. You can mainly feel it vibrating at a constant speed. Been told.could be injectors? But gonna get clarification before forking out a lot of money on new injectors
  5. bisco
    49,381
    how many miles on her?
  6. audiodave
    audiodave Active Member
    787
    268
    US
  7. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Just curious here.... and I'm wondering if this is the "vibration" your talking about.
    Do you experience this vibration right about the point where the car seems it could roll in electric only mode? If you have your display set to ECO, you'll find this right about the point where your pressure on the gas pedal puts the bar right about where the line is or slightly above it.
    ztanos likes this.
  8. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    ^I came here to ask this exact question. Is the "constant" speed right around 45ish?
    Patricia Morgan and dubit like this.
  9. ifty1989
    england
    2014 Prius c
    Excel
  10. ifty1989
    england
    2014 Prius c
    Excel
    I get this vibration around 60 mph I'm gonna try putting Injector cleaner in today and see what happen s
  11. Patricia Morgan
    sT. lOUIS
    Nicely done. Hoping to get my Prius to 180k, too!
  12. ifty1989
    england
    2014 Prius c
    Excel
    Managed to sort it out turned out to be the air intake manifold from the egr valve was blocked. All cleaned up and started running alright
