Toyota salesman claiming 2010 will get 1.8 L engine
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Jul 11, 2008.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    That's right. I was at Toyota Sunnyvale this afternoon talking with a salesman. He said, for sure, guaranteed the 2010 Prius will get the 1.8 L engine based on the Corolla. He did not say how he knows that.
    I'm like, hmmmmm, 1.8 L .. more weight, will cost more. I'll be ok with it if it pollutes less and gets better fuel economy.
  2. GeekEV
    GeekEV Member
    417
    NorCal, USA
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
  4. Flying White Dutchman
    4,374
    313
    there is going to be a model above the prius! so ik think the 1.8 will be in that car
  5. drees
    drees Senior Member
    1,782
    247
    I doubt the new engine will be significantly heavier. The problem with the current engine in the Prius is that it's based on an old design that used to be used in the Echo.
    The new engine is based on the one currently used in the Corolla which means that it will be cheaper to produce since they won't have as many blocks to cast.
    Sure, they might have been able to make it slightly lighter if they designed the block around a maximum of 1.5l instead of 1.8l, but in reality, 0.3l is not a lot.
    I think the new engine will make better use of dynamic cam/valve adjustment so it should be more efficient as well.
    As a whole, all the rumors seem to indicate that the new engine/updated hybrid system will net 10-15% better fuel economy - how much of that is the engine and how much is the updated hybrid components (and other changes) will be hard to say.
  6. Tideland Prius
    16,128
    Originally, speculation placed it as a 1.8 litre engine. It's only the latest one from C/D that says it'll get a 1.6 litre.
    Either way, it'll be from the same engine family, the ZR family. The 1.6 litre will be the 1ZR and the 1.8 litre, the 2ZR (the one in the Corolla/Matrix/xD). These new family of engines is ridiculously fuel efficient. How so? Even with a 4-spd automatic, the Corolla beat the 5-spd auto Civic in CanadianDriver's 50 litre challenge netting a final tally of 4.9L/100km or 48mpg.
  7. rfruth
    rfruth Member
    394
    Houston, Tx
    Atkinson cycle (higher compression) in G III ?
  8. drees
    drees Senior Member
    1,782
    247
    Yes, Atkinson cycle engines are a natural fit for hybrids unless you need/want the peak horsepower of an Otto cycle engine for some reason.
  9. rfruth
    rfruth Member
    394
    Houston, Tx
    So its going to involve more than just dropping the 1.8 in there ...?
  10. drees
    drees Senior Member
    1,782
    247
    Well, yeah. Just like they didn't just drop the Echo 1.5l in to the current Prius, they won't drop the Corolla/Matrix/etc 1.8l in to the next gen Prius.
    It will be interesting if it's not a 1.8l, though. What Toyotas currently use a 1.6l?
  11. Tideland Prius
    16,128
    Corolla overseas and probably the new Yaris along with new 1.3 litre engines for both Corolla and Yaris overseas.
  12. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    Let me update this - Yaris has 1.0, 1.3, 1.33 (soon) and 1.8 engines. Corolla 1.4 ZZ, 1.6 ZR, 1.8 ZR... New Avensis will probably get 1.8 ZR and 2.0 AR.
  13. lwnboy
    lwnboy New Member
    37
    Shell Beach, CA
  14. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    If they aren't going to Li ion batteries in 2010, the changes will be essentially cosmetic. The Gen II car is almost perfection--in its 4th or 5th year of production. I don't see how they can call the 2010 Gen III unless they change the battery system fundamentally.
    As for 1.8L, I'm personally satisfied with the power of the present Prius. The Prius is not a car you feel you want to drive fast--it is so quiet and smooth, you just want to relax and enjoy the ride. You don't get that feeling in most cars.
  15. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Just because the "non-atkinson" displacement is increased does not mean that the engine is necessarily going to be heavier or even use the extra displacement for the intake stroke. It would allow for the power stroke to be effectively longer, so it could be even more efficient. It's easy to see how one engine parameter can be misunderstood. Just a thought.
  16. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    if this new engine is the corollas 1.8 liter, it would be the ZR 4 cylinders that they are producing now, the major factor i believe would be dual VVT-i and the new "valvematic" system
    this would mean the new prius would be a lot more powerful than the present one.
  17. spwolf
    3,156
    440
    Eastern Europe
    You are playing with catch words... who cares if it is lithium ion or nimh or whatever they use. We care about the results. If it is more efficient while being more powerful and having more space while it is about the same size, who cares what technology it has?
    I could care less about lithium ion batteries if they are not ready.
    To claim that such new technology cant be improved is just silly. Prius has been around for 10 years now which is baby steps compared to the petrol engines that have been around for century and yet there are always some new improvements.
  18. Flying White Dutchman
    4,374
    313
    mmm the 1.0 in the 2010 prius:cool:with a turbo and supercharger of-course just in the case you need some more power that a normal 1.0 on a prius can not
    and the rest of the time.... 1.0 mmmm LOW fuel use on the highway
  19. spwolf
    3,156
    440
    Eastern Europe
    you do understand that at highway speeds, that 1.0 turbo would be boosting all the way? :). 1.0 Yaris spends more fuel at 90 mph than my Lexus GS350 AWD. It is highly efficient in the city and country roads, of course.
    Thats the problem with turbo engines - they are fine when nothing is happening but spend more fuel otherwise.
    Autobild (biggest german mag) had feature recently where they tested 20 different cars in the city, 3km driving. They had Rav4 Petrol (2.0 AZ engine, old, old) that got 12l/100km while 1.4 Twin Turbo Tiguan (which on paper has 30% better mpg got 14l/100km. Worst offender was 330 turbo that spent 20l/100km. They didnt drive the cars fast, just normal city driving.
  20. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Even a slightly larger engine will make a big difference on long hills, which is where I notice the current powerplant's shortcomings the most. A turbo would be wonderful to compensate for thinner air at higher altitudes, but it's probably too expensive and complicated for production.
