Toyota still supplying new HV batteries ? Greentec option ?
Discussion in 'Gen 2 Prius Main Forum' started by Victoria Bruce, Nov 23, 2024.
  1. Victoria Bruce
    Victoria Bruce Junior Member
    Victoria, BC
    <<If there are existing threads on these topics, please direct me. I couldn't find them.>>
    Our 2007 with 203,000 miles and original HV battery just threw the P3000 code. I took it to a local mechanic who works on Priuses who checked the codes. He said only the High Voltage battery itself has failed.
    I called the local Toyota dealer parts department who quoted a price of $CAD3121 for a new one, but said they are back-ordered. He didn't know for how long or when they supplied the last one.
    Is Toyota still supplying new batteries for Gen 2 ?
    Greentec has a dealer in Canada so would be my next option. Is Greentec reliable ?
    I don't feel handy enough to take our pack apart and start testing cells for voltage and capacity.
    Thanks !!
    51,033
    yes, they are still making them, but supply is spotty.
    greentec gets good and bad reviews. noreconditioned battery will be as reliable as a new battery.
  3. PriusCamper
    PriusCamper Senior Member
    11,982
    4,872
    Pacific Northwest, USA
    Sometimes a P3000 can be fixed by replacing the Voltage Sensor harness, which gets corrosion in the battery computer and once you clean that corrosion off and spend $50 on a new set of wires: Hybrid Battery Wire Harness for Gen 2 (2004-2009) Toyota Prius | ACENBAY the car will run great and there's nothing wrong with the pack.
    If you ever drive south of the border to the state capitol in Washington State, I'd be willing to help you out.
    97trophy likes this.
  4. Brian1954
    Brian1954 Senior Member
    1,709
    665
    South Central PA, USA
    I agree with PriusCamper. The P3000 code does not mean you need to replace the HV battery. It means that there is a malfunction in the HV battery. Trouble code P0A80 means the HV battery needs replaced. Do you have the P0A80 code?
    #4 Brian1954, Nov 23, 2024
    PriusCamper likes this.
  5. PriusCamper
    11,982
    4,872
    Of course at this point @ChapmanF usually shows up to say say there's 5 different subcodes to P3000 for 5 different reasons related to pack blocks not being balanced.
  6. Victoria Bruce
    Victoria, BC
    Good thoughts. I took the car to Tennyson Automotive in Victoria who services many of the taxis in Victoria. Almost all of our taxis are Prius and Camry hybrids. He used his reader to check for sub-codes and told me it's just the battery. He didn't tell me which codes he read.
  7. Victoria Bruce
    Victoria, BC
    We bought a brand new hybrid battery from Toyota for CAD$3200 + taxes. Tennyson Automotive installed it and all of the weird behaviour and warning lights stopped. The car runs fine now.
    But - we used to average around 50 MPG (US gallons) before the battery failed and now it's doing around 40 MPG. What should I look for ?
    Tennyson disconnected the 12V battery - I had to reset the clock and radio. I assume that's expected.
    uart likes this.
  8. PriusCamper
    11,982
    4,872
    I doubt its the battery pack... Check tire pressure... Also did you replace the tires recently? Many people get tricked into buying "safer" tires that only get 40mpg with a Prius.
    Also this time of year it's so cold out in your region if you're just driving around town 40 mpg is fairly normal for short trips in Winter.
    uart, dolj and Brian1954 like this.
  9. dolj
    dolj Senior Member
    8,186
    4,168
    Wellington, New Zealand
    It can take a while for the hybrid system to recalibrate to the best economy after a 12 V battery disconnection. Maybe up to three tanks. Also, are you resetting the tank MPG average every fill? If not, it will be a very slow process to see improvement in your average MPG.
    PriusCamper is correct in what he says about tires, winter driving, and short trips.
    Brian1954 and uart like this.
