Toyota To Debut Their Revised Hybrid Racer
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by El Dobro, May 1, 2013.
  1. El Dobro
    El Dobro A Member
    6,978
    3,213
  2. bwilson4web
    15,518
  3. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    If the Nascar network, err Speed channel, would have race coverage like they used to. I also miss WRC that they no longer air here.
    SPH-D710 ? 2
  4. El Dobro
    El Dobro A Member
    6,978
    3,213
    I'm relying on you guys to let us know how the race goes. I can only watch the first half. :D
  5. El Dobro
    El Dobro A Member
    6,978
    3,213
  6. bwilson4web
    15,518
    Was watching but had to take a nap. When I got up: "18:15:24 : Toyota #7 is having "energy recovery issues" Apparently it withdrew. So now the ranking is, 1,2,3, Audi the Toyota running #4.
    There were two races on the same track. The Audi/Toyota racers pretty well ran away from the pack. Then all the rest but there was something else.
    When in the last race, one of the diesel Audi had a problem with their flywheel based, hybrid electronics, they continued in the race with credible numbers. In contrast, the gasoline Toyota had a problem and eventually dropped out. Now failures come in many different shapes and kinds. If 'the smoke escapes,' there is little option but to pull out.
    The more tightly coupled Toyota system means a hybrid failure would lead to an early withdraw. The less tightly coupled Audi system continues on diesel power.
  7. El Dobro
    El Dobro A Member
    6,978
    3,213
    Oh well, hopefully everything will be sorted out by the next race. On to Le Mans.
  8. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    EXPUNGED.
    bwilson4web likes this.
