Toyota TSB Warranty limited to California and a few other states
Discussion in 'Gen 2 Prius Main Forum' started by joepardue, Jun 8, 2017.
  1. joepardue
    joepardue Junior Member
    Tennessee
    I am a retiree trying to make ends meet on a fixed income. I needed a reliable and economical car so after a bit of research, I decided to purchase a used Prius. I found a 2007 with 92k miles in January.
    And after about 4 months and 2k miles, I got the dreaded master warning red triangle light along with other lights. After I stopped driving I found that it would not start again unless I unhooked the auxiliary battery to clear the codes (found that here). Apparently this is a popular fault on Prius chat. I took it to a local shop and they charged me $87 to tell me that they can’t fix it to take it to the dealer. The dealer charged me $447 (generously knocking off $50) to tell me that I needed a new transaxle and it would cost about what the car is worth: $5300.
    The codes are P0AA6 526 613 which I see means that there is a high voltage short in the transaxle and they don’t have a clue as to what it is caused by or how to fix it so they just replace the whole thing.
    Further research and I notice that if I was lucky enough to live in California and a few other states that I also don’t live in, Toyota has provided an extended warranty of 150k miles or 180 months for the P0AA6 526 613 problem.
    I’m thinking that if they know it is a problem and know they have to take full responsibility for it in California and some other states, then how in name of fairness, the law, and public relations can they exclude me in my dinky non-listed state from this warranty fix?
    My main question then is: does anyone know if these sorts of state restricted warranties are enforced? Has anyone sued them over this? Does anyone have any experience successfully shaming Toyota into to doing the right thing in cases like this? Finally, any suggestions on how to proceed?
  2. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    States like ours are much more consumer oriented and less friendly to businesses. Attorney generals are much more likely and quicker to sue on behalf of the consumers than elsewhere. As such, when the defect was found, California and a few others probably threatened to sue and Toyota negotiated a deal with them. Tennessee was not part of the group and the feds didn't get involved so that's how you were left out.
    You could plead your case directly to Toyota (bypass the dealer). Some people have had success getting help with replacing batteries that failed right after the warranty ran out. There may well be a legal firm out there who might take such a case pro bono, hoping to cash in for a decent percentage of a final settlement.
    Whatever way it goes, good luck.
    #2 srellim234, Jun 8, 2017
  3. joepardue
    Tennessee
    I talked to Toyota Customer Experience Center and found that they will do nothing for me.
    I said that while I understand what is legal, they need to understand what is right.
    They acknowledge through the TSB that their product has this defect and they will fix it in 10 states, just not mine.
    From Toyota Technical Service Bulletin T-SB-0306-08:
    For California specification 2004 – 2008 model year vehicles sold, registered, and operated in California, Connecticut, Maine, Massachusetts, New Hampshire, New Jersey, New York, Oregon, Pennsylvania*, Rhode Island, and Vermont, this repair may be covered depending on vehicle model year, under the california Emission Warranty, which is in effect for 180 months or 150,000 miles, whichever occurs first, from the vehicles in-service date.
    I've found several shops around the country, none closer than 8 hours from me - that will fix this for around $2000. I'll keep looking.
    In the meantime, for the first time in my long life I'm going to contact a lawyer. This may be legal on the part of Toyota but it just isn't right and they have earned themselves a tiny enemy with a lot of time to see what I can do to let folks know just what kind of company they really are.
    49,597
    have you contacted todd at tampa prius, and steve at auto be yours? steve might be closest, not sure where in tn you are. all the best!(y)
  5. Patrick Wong
    18,200
    6,479
    A warranty describes the allocation of responsibility between the seller and the buyer with regards to product failures. As you bought a used vehicle (presumably at a low price commensurate with its age and odometer reading) hopefully the price was sufficiently low to compensate you for bearing the risk of failures.
    California can establish its own emissions-control regulations which supercede Federal regulations because of the historic poor air quality in the state due to high population density. California established the AT-PZEV category as a way to encourage vehicle manufacturers to produce low-emissions vehicles. That category requires the 150K mile warranty on certain items.
    Yes, since you don't live in CA (or several other states which adopted CA emissions regs), you don't benefit from that warranty. However, you have not had to pay CA state taxes, pay CA real estate prices and property taxes, etc etc.
    I have not heard of anyone successfully suing a vehicle manufacturer on this issue, but if you can find an attorney willing to take your case, good luck.
    With regards to the specific issue you have, as a short term measure you can continue to drive the car by first disconnecting the 12V battery to clear the DTC. Then the car can be started once. At least that will get you by for a while, until you figure out a long-term solution for this problem.
    fuzzy1 and ETC(SS) like this.
  6. joepardue
    Tennessee
    Thanks Patrick.
    I've found a garage that looks like they know what they are doing who can get a used transaxle for $700 and install it for about $800 and they have a 6 month warranty (full year for $250). My guess is that since this is such a rare problem that I'm not likely to see it again in a used transaxle, sort of like getting struck by lightning twice. But then again 'used' could mean 250k miles so who knows?
    srellim234 likes this.
  7. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    The garage should be able to tell you the mileage of the car the transaxle came out of.
  8. Patrick Wong
    18,200
    6,479
    It is a great idea to install a used transaxle. As previously suggested you should find out the miles logged on the donor vehicle. The lower the better.
    You asked what caused the high voltage ground fault. Typically a stator winding develops an insulation fault which allows up to 500 VAC to leak to body ground. This is fairly rare but certainly has happened to a number of posters here.
    Good luck with your vehicle repair.
  9. JC91006
    16,488
    8,402
    It happened to the 2005 I bought 2 years ago, I suspected the transaxle fluid was low from an axle seal leak and the seller took it on a road trip across several states. It broke down in California with 151k miles. Sold it to me for $1000
  10. joepardue
    Tennessee
    So I've been waiting for a recurrence so I can take it to a guy who offered to look at the problem for free. It's been nearly a month and a half with 300+ miles (I don't drive a lot) and NO red triangle of death!
    At this point I am going to conclude that the auxiliary battery terminals were not perfectly connected, or a bit of conductive crud got lodged somewhere in the transaxle to cause the HV short, or that the gremlin that was bedeviling my car got tired of waiting for me to go entirely daffy duck and left for a more entertaining owner.
    Whatever... I've dubbed my Prius 'Loki' and I'm going to get Loki a new auxiliary battery and have the transaxle fluid changed and just pretend this never happened. And someday I might actually relax while driving not worry that the trickster god will jump out to torment me at the least expected moment. I guess driving a Prius isn't peace love and harmony after all, more like actual life: one damned thing after another.
    Don't you just hate it when your fondest hopes get educated by reality?
  11. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    That is good news, hopefully Loki continues to shine favor upon you ;)
  12. Patrick Wong
    18,200
    6,479
    Since you don't log very many miles per month, I suggest that you use a battery charger or a battery tender to keep the 12V battery fully-charged. That will help to prevent the trickster god from playing more tricks on your Prius.
    fuzzy1, bisco and fotomoto like this.
