Toyota Will Void Warranty For EV Button ~ '04 & '05
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Brian, Oct 3, 2004.
  1. Brian
    Brian Member
    480
    Bakersfield
    Today at our OC meet we discussed how Toyota will now Void the warranty if you have an EV Button on your '04-'05 Prius. It is in the Q & A page for the '05 Prius Here
    As stated in the Q & A:
    25. Does Toyota support the modification of my Prius to be a plug-in Hybrid and run on electric mode only with a switch?
    Any such alterations, modifications or tampering with the vehicle voids the warranty and is likely to be counterproductive for air quality and Prius’ durability and safety.
  2. Brian
    Brian Member
    480
    Bakersfield
    What I don't see right is how they ALREADY put the switch on all other models they sell for the other countries but will VOID our warranty for wanting what they have on ours. It just doesn't make sense.
    -Brian
  3. toolbox
    toolbox New Member
    72
    St. Louis
    I figured this. You have to follow the terms laid out in the warranty manual provided to you from Toyota. modification to the vehicle gives them an out or excuse to shoot down any claim. it doesnt matter if you think it is right or wrong and it doesnt matter what they do overseas. warramty regulations differ from state to state. if you have a button installed i recommend you remove and hide any evidence before you take the car in. cutting into the wiring harness is a big no no. if your gonna wire switches in, try to use junctions and connectors so they can be removed for dealer visits.
    if you have a ev switch and bring the car in with a hybrid battery problem you are gonna get told by putting it in ev mode you damaged the battery by discharging it outside its set range.
  4. peart75
    peart75 New Member
    104
    san diego
    <div class='quotetop'>QUOTE(toolbox\";p=\"43100)</div>
    what's funny is that the system doesn't even allow this to happen. if the batt. gets too low it automagically kicks the engine on for regen. same goes for rapid acceleration while in EV mode.
    -drew
  5. Speedracer
    Speedracer New Member
    378
    Nagoya, Shanghai
    I agree that, alter OEM wiring harness is pre-much voiding warranty.. Specially most automobile maker picky about it(for U.S market), because too much law suits agains really stupid things... Think a moment why so many warning lables and dumb instraction for any product in U.S??? Im from consumer product development background and I heard so so many dumb things which you never thought to do.
  6. jamarimutt
    jamarimutt New Member
    985
    If it ain't broken, don't fix it.
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Old News Discussed in Previous Thread
    Bottom line is that the word "and" suggests they're trying more to avoid people adding additional batteries. Also, this disclaimer has always been in my install instructions and anyone adding the EV should be prepared to buy a new battery or HV ECU if one of those malfunctions and Toyota refuses to fix under warranty.
    Also, there is no alteration of any wiring harness. An existing feature is accessed...that's it. Fighting a refusal of warranty work would likely not be worht the legal costs, but one would probably win if you did.
  8. toolbox
    toolbox New Member
    72
    St. Louis
    proof is the biggest thing if you decide to go to court...if the insurance company can only guess what happened and thinks it is owner negect and cant prove it you got em and will win your case.... if they have proof or pics of a nitrous bottle or cut up harness you sealed your coffin. alot of times warranty companies have to look at the expense of a repair vs fighting the decision. you have to make a business decision on whether it cheaper to just buy the repair or to fight it out, but the customer is gonna be giving a hard road and it gonna take alot of phone calls and complaining.
  9. Zephyr
    Zephyr New Member
    Long Island, NY
    Even if you removed the mod before bringing it in for service, wouldn't the fact thet the car was put in EV mode be logged in the computer? I would think that would be enough evidence that the system was tampered with.
    Either way, as much as I want to do the EV mod and even have an OEM switch I now have second thoughts. I assume the other mod to enable all the nav and phone functions while the car is moving carries the same consequences as the EV switch?
    Mike V. <><
  10. efusco
    19,891
    1,196
    Nixa, MO
    First I have to ask...what consequences?? If you add a subwoofer would that cause 'consequences' to your warranty?
    Look there's just way too much hand wringing over this. In over a year of folks having the EV button no one has reported a single problem with service or warranty.
    Yes, the info that you'd used an EV mode is recorded in the computer. I suspect it logs out after a while of driving without it. But, even if it's there to be found someone has to go looking for it. It isn't as if it's stored as a DTC code, it's just stored with all the other NORMAL operational information and would take a seriously dedicated tech who knew what to look for, where to look for it, and why to look for it to find that information.
    Even if they did find it, if the warranty related problem was not a direct function of the HV ECU or HV battery, the only systems the button directly effects, they can't, legally, delcine warranty service. They have to prove that the mod did the damage....since the 'mod' is a standard feature and works exactly the same way in Japan and EU then they're going to have a darn hard time proving that your EV button did the damage--unless you did something way wrong installing it and cause another system to cause the actual problem, in which case your warranty work SHOULD be declined since you actually caused the damage.
    The NAV and BT speed sensor defeats affect nothing but the speed sensor wires. for the NAV and BT (and indirectly the Consumption graph and Energy screen simulated wheel motion). So, unless those mods cause direct damage to those systems or you did the mods wrong and caused damage to other systems due to faulty installation they can't void your warranty any more than if you'd installed all season floor mats and had a problem with the car.
    Still, if you're uncomfortable and can't afford to pay cash for the work should they decline warranty coverage then you should not do these mods. I say that never expecting to have to pay a dime, but knowing I'm able to if necessary and willing to accept the risk.
  11. Zephyr
    Zephyr New Member
    Long Island, NY
    Evan,
    I quite agree, however I have had some interesting experiences with aftermarket mods on new vehicles. My other vehicle is a Dodge Durango (talk about opposite ends of the spectrum...) and when I brought it in to the dealer for regular maintenance the head mechanic remarked "what no cold air intake yet?" and proceeded to show me a catalog of aftermarket performance parts.
    OK - so I was planning to make a few mods to try to increase fuel economy and performance anyway, so in went a really nice cold air intake and a ported and polished throttle body. The next time I brought the truck in I met with the same tech who was impressed with the mods - however when I looked and the receipt for the work an entry was made in the computer noting the non mopar parts and that these changes may void my power train warranty! I can tell you I was pissed :cussing: but I knew the risk before making the mods and was prepared to accept them. I just thought it was very questionable behavior on behalf of the service department.
    Anyway, I still plan on making the two mods to the Prius. I know the risk and the potential expense I may incur down the road as a result of the changes, but that's what makes life interesting!
    Thanks for all your help and contributions to the site!
    Mike V. <><
  12. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    As Evan noted on Oct 3rd, the word AND is important. From the original first post on this thread:
    The question specifically relates to modifying the car such that you can plug it in to charge the battery.
    I suppose you could buy an official Toyota hybrid battery charger for however many huge bucks it costs and charge the standard battery overnight. However, the storage capacity is SO small that it would be a joke to bother. You would have to add battery capacity as well.
    Now, besides adding the (possibly OEM) EV switch, you are mucking with the batteries and who knows what the computers do with that. OK, Wayne probably knows :). I suspect he also did his experiments knowing he voided the warranty even before Toyota got nervous about the whole 'plug-in hybrid' thing got started some months back.
  13. naterprius
    naterprius Senior Member
    1,843
    Zephyr, the action your Dodge dealer took is illegal. If you do have problems with the powertrain on your Dodge and need warranty service, contact Dodge corporate, they know the law and should accomodate you. If they do not, get a lawyer, they will fold like a cheap suit. The Magnuson-Moss warranty act is quite clear. The warranty is now void on your air intake, but no more. If your air intake is missing an air filter or includes nitrous that's another story.
    Nate
  14. JHartman
    JHartman New Member
    45
    Los Angeles
    I'm wondering how many Toyota service people will notice you have the EV button if you don't tell them? I mentioned to my old service manager that the buttons exist on the Japanese Prius and they were totally clueless about it. This is a service center is Los Angeles that sees a couple of '04s every day. I didn't tell them that I have an EV button and it has never been noted. What they don't know won't hurt us.
    I honestly don't see how the button can hurt the battery. I use it every day when I leave my home and on the couple of ocassions when I've forgotten to hit the button a second time it kicked off by an increase in acceleration. The vast majority of the time I only lose one or two bars on the battery display. If I really had a battery problem I might consider hiding the button, but I highly doubt whether this will ever happen.
  15. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I suspect since it is not even an option in the U.S. cars, the service techs aren't trained on it at all. Probably not even mentioned as a footnote.
  16. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Toyota is unable to void the warrany on the car for installing the OEM EV switch using their OEM wiring harnesses. Magnum Moss act prevents them from using that as an excuse. As has been mentioned, the only way that they can void the warranty on the car is if you get in there and start cutting and splicing, damaging something in the process. Now, if the EV switch itself fails, then you are out the replacement cost of it, since it is not offered here.
