Toyota's transmission patents (reply for dennis)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by zackkahry, Jun 14, 2006.
  1. zackkahry
    zackkahry New Member
    16
    those are cute, check these out:
    5558595
    5558589
    5558588
    those took me ~3 seconds to find, all of them are transmissions using planetary gear assemblies, owned by GM, issued before toyotas.
  2. zackkahry
    16
    5730676
    3623568 < nissan
    3861484< 1972, private
    Let me know if you have any questions ;)
  3. brandon
    brandon Member
    771
    Manhattan, KS
    I'm confused. Is this in response to another thread somewhere else? Why not just post to the original thread?
  4. zackkahry
    16
    <div class='quotetop'>QUOTE(brandon @ Jun 14 2006, 03:28 PM) [snapback]271283[/snapback]</div>
    it got locked because some of you guys cant handle the truth.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    The original thread was closed. I''m allowing this one as long as it can stay on topic and not get hostile.
  6. brandon
    brandon Member
    771
    Manhattan, KS
    <div class='quotetop'>QUOTE(You're nuts @ Jun 14 2006, 02:31 PM) [snapback]271285[/snapback]</div>
    :lol: lol!
    I love it when people can't take a hint.
  7. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(You're nuts @ Jun 14 2006, 02:42 PM) [snapback]271253[/snapback]</div>
    It's one of those obscure automotive facts, but GM did mass produce a planetary gear automatic transmission for many, many years starting in the late 30s.
    http://en.wikipedia.org/wiki/Hydra-Matic
  8. efusco
    19,891
    1,192
    Nixa, MO
    Good God people. Play nice or don't play.
    No one claimed that Planetary gears/systems were "invented" by Toyota. Planetary gears have been around for a very long time for various uses.
    However, noone used one in quite the same ingenious way that Toyota has in the HSD. It's in the implementation.
  9. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    My understanding of US patent system is that it is very messed up.
    The reviewers are NOT doing their due diligent. The inventors are
    not responsible for filing somethings that prior art exists (no penalty). Basically,
    a US patent does not mean much. By granting you a patent, the US govenment
    does not endorse your invention. It just means you have passed the
    process of official review. It is up to the court (after tons of money spent)
    to decision who has the ultimate right of the invention. :(
    P.S.
    I personally own 5 US patents, 2 pending. I have dealt with more than
    5 patent attorneys.
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Automatic transmission use multiple planetary gearsets. HSD use just one as a Power Split Device and interconnected ICE and two electric motors. So, the whole hybrid powertrain becomes the transmission eCVT. The patents I posted before described the operations in detail. If you want to learn more about PSD, I have a couple of great links.
    http://www.ecrostech.com/prius/original/Un...ng/Contents.htm (Click on the Power Split Device link from there.)
    How Toyota hybrid is different (hybrid of hybrids) from other type of hybrids.
    http://www.toyota.co.jp/en/tech/environment/ths2/what.html
    Dennis
  11. zackkahry
    16
    <div class='quotetop'>QUOTE(ceric @ Jun 14 2006, 04:11 PM) [snapback]271316[/snapback]</div>
    this is a fairly accurate assessment. In a class with crowded art, any minor change can get you a patent. I often times find myself getting frustrated at them because they are so incompetent that it truely is a waste of time. I'm sure you have heard of companies getting patents, and then losing patent infringement suits (such as amazon.coms 1 click shopping) this really shouldnt be happening, as the USPTO should be doing their jobs instead of just sending everything through.
  12. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    FYI, the Model T used a dual planetary transmission. B) :rolleyes: :lol:
    There was no clutch or fluid coupling. Each planetary had a band around the ring gear, which was tightened by pressing a pedal. There were two pedals, in the now-normal brake and clutch positions. For an emergency stop, you just pressed both as hard as you could and hauled like hell on the brake lever. :blink:
  13. GasGuzzler87
    GasGuzzler87 New Member
    131
    I prefer my manual gearbox. Cool that you guys got a mass pateneted gearbox though.
