TPM warning light off after winter tires with no sensor installed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toyolover, Nov 15, 2016.
  1. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I recently installed a set of winter tires on steel rims with no TPM sensors inside. I would assume the TPM indicator would stay blinking or stay on all winter season until I put back the all-season set with TPM sensor inside.
    However, below is the current situation:
    On the first week or so, the TPM indicator blinked for a minute and then stayed on when I drive.
    After the first week or so, the TPM indicator blinked for a minute and turned off when I drive.
    Starting yesterday, the TPM indicator won't blink and stay off when I drive.
    (Note: The TPM Warning light bulb is not burned out because it would come on upon engine start up.)
    Is this normal? Anyone has the same issue?
  2. Mendel Leisk
    41,876
    I get various, similar things happening with the light, same situation as you. With us, the OEM tires (with TPMS sensors) are in a stack in the garage, just a few feet from the car. Maybe the car keeps detecting, then losing the sensors, and this causes the behaviours? Your set up is similar?
    I know there's delay in the reaction, probably by design. I'm thinking it's all fine, and come spring when you install your regular tires it'll be back to normal.
    toyolover likes this.
  3. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    A small piece of electric tape, placed over the light will fix the problem, remove when not needed.
  4. Mendel Leisk
    41,876
    Meh, what problem? There are passenger seat air bag lights always on, nobody get upset. Putting tape over a warning is overkill, will leave residue, and if you manage to forget to remove it in spring...
  5. toyolover
    toyolover Member
    441
    67
    toronto, canada
    The problem now is the warning light is off !
  6. Mendel Leisk
    41,876
    And that's a problem, lol?
    Where are the OEM wheels? Near where you're parking? That's my best guess.
  7. ForestBeekeeper
    ForestBeekeeper Active Member
    779
    308
    Maine
    Our TPM indicator randomly turns on and off, all winter long. It is only a useful indication when the summer tires are mounted.
  8. mrbigh
    3,686
    699
    Long Island, NY
    If the TPMS sensor does not receive any signal back, it will go to sleep until the TPMS reset button is pressed again and it will start searching for the FR signal back from the rims.
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The "problem" is some owners live where -any- light will make them fail some govt. test.
    But it seems to be "self fixing". ;)
    So put your summer wheels/tyres in an aluminised bag (or a great big can) if they are stored near the car.
  10. Mendel Leisk
    41,876
    Not in Canada though.
  11. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    I don't know if Toyota has tweaked the computer for later models, but for my 2006 it can take a couple weeks for the TPMS to realize it does not have a good reading from the tires. Probably it takes a longer trip for the computer to say "hey I ain't gettin no signal from that tire". In this case if your tires are in the garage you may be updating the data when you start up, and then it is good until computer figures out the data is old.
  12. toyolover
    toyolover Member
    441
    67
    toronto, canada
    The OEM wheels are inside the garage and the car is parked outside on the driveway. The distance is about 20 feet away. The issue here is during the first week or so and when I drove away from my house, the TPM warning did come on because it did not detect the TPM sensor signals. The situation is unchanged but the TPM warning light is not coming on any more. I guess it must be like mrbigh's reply that it is designed to go into sleep mode after not receiving TPM signals after a certain period of time. I don't need to warning light to be on and don't mind it is off because I check the tire pressure regularly. All I care is when I put the all-season set back, I don't have to pay the dealer to re-program something to make it work again.
  13. Mendel Leisk
    41,876
    You should be ok come spring. :)
  14. PosauneGuy
    PosauneGuy Member
    123
    91
    California, here I come...
    2025 Prius
    Here's what's probably happening: You're probably parked just far enough from your OEM wheels that your car is sometimes picking up the TPMS signal from the OEM tires to reset the light. I have found that it takes 20 minutes of the car being on for the TPMS system to recognize that the sensors are not there. After 20 minutes, the light will start to blink and then turn steady. If the Prius doesn't reassociate with the TPMS in your OEM tires after the light has come on, it will blink when you start the car and then turn steady. If you start your car in your driveway after the light has been on, it will start to blink, but if it detects the OEM tires while you're still in the driveway, the light will turn off. You can drive for 20 minutes before the light will turn on again. If you drive for less than 20 minutes, the TPMS light will not turn on.
    So in summary:
    1st week: TPMS was not finding OEM tires and light stayed on.
    2nd week: TPMS light was on when you started the car (blinking), but detected the OEM tires before you left the driveway, so light turned off.
    Starting yesterday: Car is reading the OEM tires so no light. (Also driving for less than 20 minutes, so the light does not turn on.)
  15. toyolover
    toyolover Member
    441
    67
    toronto, canada
