Tpms 2012 Prius C
Discussion in 'Prius c Main Forum' started by Phyl, Jan 26, 2024.
  1. Phyl
    Phyl New Member
    Nashville
    Hey, Grandma here, my pressure light won't go out. So I assume I need the TPS thing. The dealer wants 75.00. I need a to know which best aftermarket one I should get. Social security sucks. Hope I'm doing this correctly, be patience with please. Oh, tried a reset, light flashes like crazy then stays on.
  2. John in Vermont
    John in Vermont Junior Member
    31
    Rochester, Vermont
    2018 Prius c
    The car will run without a problem and still be safe even if you don't do the repair. You will need to buy a good tire pressure gauge and check the tires every couple of weeks, but you should be doing that anyway since the TPM's aren't reliable anyway.
