TPMS and tire rotation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dave001, Oct 16, 2009.
  1. Dave001
    Dave001 New Member
    I have a 2010 Prius, does any one know if you need to have the TPMS reprogrammed if you rotate your tires is the ECU and tire sensors position aware or it does not matter?
  2. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    You won't have to have the TPMS info reprogrammed (which the dealer has to do) but you will have to adjust the tire pressures since the front/rear tires are different, and then you have to reset the pressure calibration (button under steering wheel), p 443 in the owner's manual.
  3. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    +1 Exactly correct. The Gen 3 TPMS system does not track location of the tires, so if you keep them all at the same pressure, you won't need to do a thing. If you keep front and rear at different pressures, as most people do, you'll need to adjust the pressures and reset the calibration, as detailed above.
  4. venom700
    venom700 Just call me Brian...
    196
    35
    Bethesda, MD
  5. venom700
    196
    35
    Bethesda, MD
    I still think you'd have to check the pressure no matter. The car does not have a 50/50 weight distribution from what I understand (couldn't find the exact numbers on the Toyota website).
  6. Dave001
    Dave001 New Member
    Thanks I did not realize you have to reset the button. I assume you do this once you have the correct tire pressure on all tires and the ECU this reset with the current tire pressure for reference.
  7. walterm
    466
    202
    34
    2022 Prius Prime
    That's correct.
  8. 2010priusowner
    2010priusowner New Member
    37
    FL
    Well that is a new one on me, just why would these most people you mention keep different air pressure in the front than in the rear? Yes I know the weight distribution is not 50 / 50 and never has been on most vehicles, so why would anyone do this on a Prius ? I am very curious to know.
    Oh yeah one other thing do the plastic covers need to come off to rotate tires or not?
    Thanks.
  9. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Because the Toyota recommended PSI is different for front tires than rears--see the sticker on the driver's side b-pillar.
  10. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Higher pressure on the front also helps to ensure that you will have the correct amount of understeer.
  11. 2010priusowner
    37
    FL
    Oh darn I was hoping for some new reason that was Prius specific like some cool fuel savings reason or some other Prius only reason.
    Thanks, and by the way I reread what I wrote it sounds snotty did not mean it that way.
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    It's no big deal one way or the other, but you don't need to reset the button for a tire rotation. The standard set point won't give a low pressure alarm until tire pressure has dropped well below the set point so 2 psi doesn't make much difference to the TPMS.
    IIRC, PC chat lore has it that the TPMS doesn't give a warning until tire pressure drops 20% below the set point.
