TPMS code C2123, ID3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RMB, Mar 26, 2018.
  1. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Hi folks, bought mini-vci more than a month ago and finally set it up and able to play with it for the first time last Saturday.
    Reason was to look at the TMPS light and code, what I found was C2123 and C2177. Thinking back couple years ago when the guy was installing the pressure sensors, one was a bit dirtier than others, and as expected, older sensor that's now dying.
    So question is, is there a way to find out where is the current location of the bad sensor, ID3? I don't want to remove one wheel at a time and roll it 100ft out until data shows it's out of range.:ROFLMAO:
    Thanks in advance.
  2. Mendel Leisk
    38,738
    Reduce pressures in one tire at a time, identify which one's dropped with Techstream?
  3. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Ho ho ho! Brilliant idea! Thank you very much!!!;)
    Raytheeagle and Mendel Leisk like this.
  4. Mendel Leisk
    38,738
    Not original, but hey.
    Raytheeagle and RMB like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    You play to your strengths(y).
    RMB and Mendel Leisk like this.
