tpms sensors?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by 4rpr15, Jul 25, 2016.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Does the '16 Prius Two have tpms sensors?
    I'm replacing my rims and need the info.
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Silly rabbit, trix are for kids. Of course they do. All new cars have them nowadays. Federal mandate...
    That's okay, I am on my first cup of java too. ;)
    4rpr15 likes this.
  3. Mendel Leisk
    38,726
    The TPMS sensors may or may not fit on your new rims, from what I've read here. Depending on the contours of the new rim.
    4rpr15 likes this.
  4. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Amazon has a pretty good selection of TPMS sensors including OEM Denso for Prius.
    Not sure if Gen4 takes the same though (Amazon site is pretty good if you put your model in tells you if it fits). You'll need help from tire shop or DIY via Techstream to set up for new TPMS codes.
    4rpr15 likes this.
  5. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    What do they cost these days? When they first came out they were pricey.
  6. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    ...at the moment they seem to be running $30 each (per tire) for Denso or Dorman on Amazon. Need to figure out which Denso is best for Gen2 Prius as Amazon fit guide is not saying right now.
