TPMS Swap Cost
Discussion in 'Gen 3 Prius Accessories and Modifications' started by venom700, Sep 10, 2009.
  1. venom700
    venom700 Just call me Brian...
    196
    35
    Bethesda, MD
    Has anyone has their sensors swapped from the stock wheels/tires to aftermarket? If so, what was the cost for that. I am looking at upgrading to 17" combo & want to know if it's worth having them swapped or just buying new ones.
    Also, does the dealer have to do any programming with a swap of them, or just with new sensors?
    Thanks!
  2. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    I just did mine yesterday Venom. Was $15 per tire for mine although I was swapping my factory 17" tires over to the new wheels. All they have to do is literally deflate the tire, break the bead and unscrew the sensor from the valve stem hole. Not a big deal really, but would guess that it would be somewhere between $5-$15 per tire depending on your shop.
  3. venom700
    196
    35
    Bethesda, MD
    And I take it once installed on new tires, there is no need to re-do any programming but to merely re-set the monitoring level?
  4. SkyDa-GS
    SkyDa-GS New Member
    NJ, USA
    I Paid $60 for 4 TPMS swap from 15" stock into 17" aftermarket wheels. You don't need to go back to dealer to do any programming. :)
  5. venom700
    196
    35
    Bethesda, MD
    Thanks, I figured with the "swap" that it would be as such. Only concern is, if I buy a new wheel/tire combo already mounted/balanced, will adding in the senors afterward cause me to get them re-balanced?
  6. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
    Of course it would. You have to deflate the mounted tires to put the sensors in, then reinflate and re-balance to compensate for the sensor, no?:confused:
