TPS =17
Discussion in 'Gen 2 Prius Technical Discussion' started by douglas001001, Aug 15, 2007.
  1. douglas001001
    douglas001001 smug doug
    222
    Chicago
    Just curious if any of the technically knowledgeable or can-view'd people could verify what I think is happening in the following situation.
    When at highway speed and knowing I'm going to slow down I sometimes go to tps = 17, which leaves ICE on at idle rpm with scan gauge gph = .2 or .3. When I do this it seems like the gearing friction goes away and the car is coasting similar to putting a manual transmission into neutral and coasting with ice on.
    If this is the case, I think this might be a good alternative to warp-stealth when exiting freeways or for downhill segments immediately followed by P&g friendly terrain in cold weather when a ICE-off glide at higher speeds cools the cat to the point where forced ice on occurs following the glide.
    (one portion of my route is a long downhill to 4 miles of slow and go where I had forced ice on after gliding during the downhill in cold weather)
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The engine loses surprisingly little heat even during very long
    warp-stealth glides. Between the TPS you see and the full valve
    retardation, the net airflow through the engine seems to get reduced
    to almost nothing. Don't believe the GPH figure -- the ECU misreports
    that during fuel-cut states, or the OBDII device is doing improper
    math based purely on MAF figures. WS is a very low-friction state
    for the engine to be in, and the longer you can hold it the better
    overall you do.
    _H*
  3. bwilson4web
    15,513
    <div class='quotetop'>QUOTE(douglas001001 @ Aug 15 2007, 11:34 AM) [snapback]496199[/snapback]</div>
    Is "tps = 17" something displayed by an after market OBD scanner?
  4. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(bwilson4web @ Aug 15 2007, 03:42 PM) [snapback]496330[/snapback]</div>
    Throttle Position Setting, displayed by ScanGauge.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I was quite amazed how narrow the "band-gap" was to get into "warp-stealth". Looking for really thin flexible sole shoes to make it easier to get there. ;) My Scangauge II also displays the same readings you got, though I haven't looked at the tps reading. Those with Can-view have confirmed there isn't actually any fuel being injected.
  6. 1fixitman
    1fixitman Member
    182
    Augusta, GA
    <div class='quotetop'>QUOTE(David Beale @ Aug 15 2007, 05:41 PM) [snapback]496419[/snapback]</div>
    I have been watching TPS on my SGII for a few days now mostly looking at what the best efficiency is for going up the hills I regularly travel too and from work as I think monitoring the 12V battery is.....well....boring.....so I decided to watch Throttle Position Sensor/Setting. I will look at what the TPS shows for all neutral stealth down hills that I do to see if it is 17 or not. I can tell you that without placing my foot on the pedal it is the number 11. I will keep a sharp look on my commutes (a whole 17 miles)
  7. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(douglas001001 @ Aug 16 2007, 01:34 AM) [snapback]496199[/snapback]</div>
    Scangauge II displays incorrect data on such fuel cut mode.
    http://priuschat.com/index.php?showtopic=34275&st=1
    Ken@Japan
  8. douglas001001
    222
    Chicago
    <div class='quotetop'>QUOTE(D Rock @ Aug 15 2007, 07:12 PM) [snapback]496531[/snapback]</div>
    ws (14/15), no arrow glide (14), ev assist in stealth mode ('harder' 14 and 15). 16 + will light the ice. 16 and 17 seem to be low/no fuel ice on coasting. The main inquiry for the post was to see if in 17 the gears are "freewheeling" and its like you're coasting in neutral.
    re David: if you are watching scan gauge trying to get into ws, let off completely until rpm hit 960 then reapply pressure. Once ice is off and is in battery spinning mode its much easier to get into the glide.
    re hobbit's answer: I'm not seeing engine temp go down, but a long ws glide at below freezing outside temps seems to put the car back in s1 like operation with ice on at all times, so I'm guessing it is cat converter temp too low. A couple of hard pulses usually get it back to normal so I was hoping that tps 17 was low gas flow enough to keep the cat warm while coasting in below freezing temps.
