Tracking fuel efficiency in the Prime
Discussion in 'Gen 5 Prime Charging' started by Zyrian, Mar 21, 2024.
  1. Zyrian
    Zyrian Junior Member
    40
    25
    ATL
    2023 Prius Prime
    SE
    I have a feeling some folks buying these cars are as OCD/spreadsheet obsessed as me. I tracked gas mileage for all my cars for about 15 years (just recording mileage / fillups / building some graphs and calculating averages like cost per mile).
    Prime put a wrench into it because car's software is beyond useless to show any sort of useful info, and after 2 months all I could come up with is to add a sheet to track all charging sessions with estimated kWh used. I can't track EV only driving miles so I add cost of kWh to cost of fuel for each gas fillup and that gives me relatively accurate cents per mile driven.
    Anyone with other approaches / ideas / comments that this is waay silly and I should just enjoy the car?
    I fully realize that Prius efficiency by itself makes it one of the cheapest cars to drive in the universe, adding charging to it cuts it down any further, so the most expensive part is my time $/hr spent monkeying with spreadsheets :)
    RandyPete likes this.
  2. RandyPete
    RandyPete Member
    172
    53
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Any examples of your spread sheets or graphs ?
  3. Mendel Leisk
    38,644
    Your car being a plug-in, not sure how much of this is relevant, but some thoughts:
    1. At least until the advent of gen 5, Toyota cannot restrain themselves, from lying through their teeth about the mpg. With our gen 3 the fibs settle in around 7.11%, optimistic of course:
    2. The only data I take from the car is the odometer reading at fill-up, well plus the the car displayed fuel economy (just for laughs). With the odo number, plus the gas pumped from the receipt, what more do you need:
    (Uh oh, gotta fix that last date)
  4. Zyrian
    40
    25
    ATL
    2023 Prius Prime
    SE
    Here's mine:
    Only 2 real fill-ups, last line is my rolling estimate of the next one. kWh are sourced from a separate sheet that has full charge log, used to get them from Kill-A-Watt meter, now with L2 it's math based on OBD2 SoC % numbers adjusted with 10% estimated charge overhead, times my effective kWh cost with all the fees and taxes included.
    iMPG is what the car shows, MPG is math. cents/Mile is self-explanatory, the little weird number is the difference between MID MPG and math MPG (lies/optimism like in Mendel's post above).
    Values in bold I type in, the rest are formulas.
