tracking my mileage
Discussion in 'Gen 2 Prius Main Forum' started by DaveR_NJ, Mar 8, 2007.
  1. DaveR_NJ
    DaveR_NJ New Member
    Can anyone suggest a way to track my mileage fuel consumption?
    Pen and paper? Slick excel spreadsheet, thanks!
    Dave B)
  2. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    <div class='quotetop'>QUOTE(DaveR_NJ @ Mar 8 2007, 03:07 PM) [snapback]402377[/snapback]</div>
    Whatever works best for you is the best way to go. :)
    I keep a pen & paper in the car then put the numbers into a spreadsheet. I track both calculated & MFD MPG. If you're filling up in NJ, you won't always get a consistent fill. That's why I track the MFD as well. I've seen successive tanks have MFD averages around 55, but get calculated as 63 and 49. Damn that self-serve!
  3. dandude505
    dandude505 New Member
    Greenhybrid.com
    Everytime you fill up with gas, you enter how much gas you filled up, and either your miles since last fillup or your overall mileage.
  4. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    Click on my signature.
    that is how I keep track of mine and it also gives me a snazzy sig :)
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    PDA--couple programs, I use one called "Highway"...google should help
    Online--GreenHybrid is the original, but rather limited data entry, Cleanmpg.com has more options for data entry and their signature image shows more data...IMO, I'd support cleanmpg.com, but that's a personal preference and I use both sites.
    I keep a pen and paper spreadsheet for back-up and recording each tank. I think Tony had a spreadsheet he circulated at one time and john1701a.com has one you can use as well I think.
  6. SomervillePrius
    944
    Somerville, MA
    haven't checked cleanmpg... will take a look at it. I would like to see the combine EPA number!
  7. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(efusco @ Mar 8 2007, 12:50 PM) [snapback]402405[/snapback]</div>
    Up until a week ago, I kept the mileage on the gas receipts and entered them into a spread sheet. Unfortunately I have lost one or two of those slips.
    I just got a PDA last week and have already started entering that information in it. I'm less likely to lose that.
    The added advantage is that I will be able to use Wayne Brown's Prius Palm Simulation program. I hope he gets around to officially releasing it soon.
    Dave M.
  8. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(efusco @ Mar 8 2007, 03:50 PM) [snapback]402405[/snapback]</div>
    And if you have a Palm device, check out MyCar. I've been using it for almost a year. After each fillup is entered into the Palm, I later enter the figures into both the Greenhybrid and CleanMPG databases.
