Traction Battery 3rd gen pack in to 2nd pack
Discussion in 'Gen 2 Prius Main Forum' started by John in AZ, Jun 12, 2015.
  1. John in AZ
    John in AZ Junior Member
    After paying for a cheap battery fix & having it fail twice I am looking at other options. I was looking for a good used newer battery but found a 2013 pack for $750 and since age seems more important than anything I like the idea of buying it and taking the guts out to put in my 05 case & electronics. Is this feasible? I know in the past there was talk of using 3rd gen c ells but cant find the threads now.
    Thanks
    John
  2. Patrick Wong
    18,200
    6,474
    That is what I would do if faced with a 2G traction battery failure.
  3. brucebee
    brucebee Junior Member
    84
    vista, ca
    I have heard that the cells used in the newer gen2 batts are the same as the gen 3 batts. Can someone verify that? Just had a new hvbatt installed today in 04 and I hope it goes farther than the 177400 the last one went. Not really complaining but I live in a mild climate
    49,490
    that remains to be seen, but some would say it's more about the eleven years than the 177,000 miles.
  5. brucebee
    84
    vista, ca
    Yes, I guess that was a good enough run. My battery checked at less than .10/ volt difference on all banks but 1. It was all I could do not to try to repair the battery. As everyone knows it is a problem if it goes out a month later. I did drive it about 60 milles after it was diagnosed to get the install done. I have driven about 140 miles and my meter says I am getting about 5mpg better. I know it is too early to tell but it seems to glide and run more on the battery. I saw a post where someone said the cells on the newer II batts had the same #s as the III batts but did not verify. Next oil change am swithching to synthetic oil as I want the motor to last as long as the battery.
  6. miso03
    miso03 Junior Member
    44
    Bratislava, Slovakia
  7. jeff652
    jeff652 Senior Member
    606
    623
    Idaho
    We have several customers who have used 3rd gen modules in a 2nd gen without issue.
