Traction Battery & Fan Vents Preventive Maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius_Angie, Apr 18, 2020.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    P_20200216_145537.jpg I just bought a $1000 white beat-up 2010 Prius with 298,000 miles. A lot of work to be done. Great 65'F day outside for a 5hour fun filled day of maintenance to the traction battery & fan/vent. Electric drill and magnetic bits saved loads of time.
    UPHOLSTERY TEARDOWN
    - filthy upholstery
    - cleaned out spare tirewell; 2x rubber plugs come out for easy hosing down of bay
    - unplug both batteries: HV traction and 12V
    - found $0.85 behind seat cushions
    FAN/VENTS REMOVAL
    - filthy/dusty vents; all went into the bath tub for a thorough washing
    - fan was heavy with dog and human hair
    - used bleach mix & q-tip buds to spray bottle clean fan. Best to hold fan facing down and to spray up into the fan; try your best not to get the motor wet. I've become efficient over the years--- down to <5min clean job
    TRACTION BATTERY
    - filthy battery terminals; brush down with plastic brush
    - Electric drill and magnetic bits saved loads of time for removal.
    - do not use drill to em-place nuts; damage fear of cross threading and overstress on module threads.
    - sand down those brass copper bus bars; i use a 3M material akin to dishwashing pad
    - i have at times replaced a few copper bus bars with zinc coated; but my engineer friends tell me copper is ~4 times a better conductor over zinc; but zinc corrodes less: tradeoffs.
    - 2 part solution clean of vinegar, then stabilize with baking soda solution
    - refit with dialectic grease 9mm socket; hand tighten
    ROAD TEST
    - good to go on first try; i must be getting a little better at this process. ; )
    - i shall revisit this compartment at around ~400,000 miles.
    - time for margaritaville!
    P_20200418_123344.jpg P_20200418_123416.jpg P_20200418_123510.jpg P_20200418_123545.jpg P_20200418_122312.jpg P_20200418_122315.jpg P_20200418_122322.jpg P_20200418_122326.jpg P_20200418_122329.jpg P_20200418_122335.jpg P_20200418_123356.jpg P_20200418_123535.jpg P_20200418_123405.jpg P_20200418_123429.jpg P_20200418_123435.jpg P_20200418_123446.jpg P_20200418_123452.jpg P_20200418_123756.jpg P_20200418_124823.jpg P_20200418_124831.jpg P_20200418_124839.jpg P_20200418_124842.jpg P_20200418_140502.jpg P_20200418_142324.jpg P_20200418_142331.jpg P_20200418_142337.jpg P_20200418_135556.jpg P_20200418_142750.jpg P_20200418_142753.jpg P_20200418_144934.jpg P_20200418_135547.jpg P_20200418_155945.jpg P_20200418_155948.jpg P_20200418_155951.jpg P_20200418_160452.jpg P_20200418_160027.jpg P_20200418_160115.jpg P_20200418_160316.jpg P_20200418_161833.jpg P_20200418_161836.jpg copper zinc conduct.jpg
    #1 Prius_Angie, Apr 18, 2020
  2. ASRDogman
    ASRDogman Senior Member
    7,959
    4,045
    Seems like a good deal. How's the motor?
    you've already done a lot of work on it!
    Prius_Angie likes this.
  3. Prius_Angie
    245
    229
    Saint Louis
  4. ASRDogman
    7,959
    4,045
    Well, hopefully, no oil burning. Too bad there's no easy way to replace the valve guide seals.
    How is the cooler? Was/is it clogged? Was the intake full of oil? EGRN passages clogged?
  5. Prius_Angie
    245
    229
    Saint Louis
    This EGR system fix will be content for another thread, but ...
    there was evidence of HUGE oil burning; Im contemplating an Oil Catch Can
    the entire EGR system was clogged; pipe clogged; valve stuck, cooler like concrete. I undid the cooler in 2 hours with chemicals, a drill and coat hanger; way too much work. Can drive prius on highway at 70mph, but still have some engine ping/misfires. Not out of the woods yet. EGR valve in the mail.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Why not use a pressure washer instead of sluggin it out for 2 hours:whistle:?
    10 minutes and you'd have been all set;).
    Maybe next time:).
    There will always be that, just remember it(y).
    RMB and Prius_Angie like this.
  7. Prius_Angie
    245
    229
    Saint Louis
    RTE,
    I read a few points to that pressure washing online & on Priuschat, but just after I put 2hours into the cooler effort.
    too bad i didnt see it before :(
    but rest assured, i will pressure wash it next time I come across a concrete EGR cooler--- thanks.
    Raytheeagle likes this.
  8. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    The pressure washer is truly the best tool set up to clean the egr cooler;).
    We once did 3 coolers in 15 minutes at one of the Bay Area meetups:).
    Good luck with the rest of your maintenance(y).
    Aaron Vitolins and Prius_Angie like this.
