Traction Battery Preventative Maintenance - Hybrid Automotive Chargers
Discussion in 'Gen 2 Prius Technical Discussion' started by jeff652, Aug 1, 2014.
  1. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    As many of you know my company, Hybrid Automotive LLC, recently released our in car Prius HV traction battery Charger/Discharger (aka grid charger). It's a sub-$400 patent pending hybrid battery charger/discharger that allows for quick, easy in car charging & deep discharging of the HV traction battery. When used as preventative maintenance, our Battery Charger/Balancer enables people to save thousands of dollars in avoided or delayed battery replacement costs.
    I'm excited to announce we are working with Danny to become a PriusChat/Shop vendor and forum sponsor. We are also going to be a TGB4 2014 Sponsor :). With Danny's blessing, I'd like to formally introduce our products:
    Our patent pending sub $400 Hybrid Battery Charger/Balancer allows for quick, easy in-car hybrid battery pack charging, discharging, and cell re-balancing. The hybrid battery never has to be removed from the car to use our products. Our proprietary hybrid battery cooling fan control ensures the traction battery is properly cooled throughout the charging & balancing process - without draining the car’s 12V auxiliary battery.
    We have sold over 600 of these already to Toyota & Honda owners all over the world. In the Honda market, we have a >97% success rate extending the life of hybrid batteries. We released our Prius products in May and are already receiving very positive reports, including increased MPGs and EV mode operation.
    While preventative maintenance is the best way to use our products, if you already have experienced battery failure symptoms due to cell imbalance, our Hybrid Battery Charger/Discharger is still a good choice to consider. Over two-thirds of our customers have already received a hybrid battery DTC trouble code before purchasing. In over 97% of failures due to cell imbalance, our customers report restored battery performance that gets them back on the road for an extended period of time.
    Technical specifications (94-09 Prius):
    Input Voltage: 88 ~ 264VAC
    Input Frequency: 47 ~ 63Hz
    Input Leakage: <2mA / 240VAC
    Output Voltage: 0 - 250V
    Output Current: 350mA CC
    Max rated ambient temperature: 100 degrees Fahrenheit (38 degrees Celsius)
    Installation is easy and takes less than two hours to complete. Please feel free to PM me, reply here, or visit our website for more information:
    Hybrid Automotive - Grid Charger - Hybrid Battery Rebalancer
    You can purchase the Grid Charger in the PriusChat Shop here: Hybrid Battery Preventative Maintenance Grid Charger for 2004-2009 Toyota Prius - PriusChat Shop
    Thanks for reading
    Jeff
    #1 jeff652, Aug 1, 2014
    51,708
    great product, all the best!(y)
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Good luck Jeff. Hope it helps the masses.
    Ron (dorunron)
  4. vskid3
    vskid3 Active Member
    773
    228
    Looks great, I'll definitely try one if my battery kicks the bucket.
  5. Power350
    Power350 Junior Member
    Bonham, TX
    Hello Jeff, for the dischargers your developing, will there be a delay for the prius or will it be available at the same time the insite ones are?
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,382
    3,244
    Madison, Wisconsin
    Vskid3, the Hybrid Battery Charger/Balancer can easily used BEFORE your battery goes bad.
    It can be used as preventive maintenance for older batteries.
    Once a year, do a few cycles of Charging/Balancing to keep your pack healthy.
    Waiting until your pack has failed misses out on a key benefit of a Hybrid Battery Charger/Discharger.
    edthefox5 likes this.
  7. jeff652
    607
    624
    Idaho
    The soon to be released advance variable load discharger will be for all Prius 1999 and newer. I'm guessing we are still a few months from release. We are finalizing the enclosure and simplifying the user interface now. Here is a sneak preview of our most recent prototype:
    Yes, this is very true. The sooner you start using the Charger/Balancer as preventative maintenance for your battery, the longer you will extend its lifespan.
  8. bisco
    51,708
    will this work for the pip?
  9. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    It seems quite a bit larger than the one in your first picture inside the trunk of the car??
  10. jeff652
    607
    624
    Idaho
    The pip use Li which we have not yet investigated for compatibiltiy wiht our products. I suspect (hope) the pip would have some sort of cell balancing provision worked into the software by Toyota, but that is speculative.
    Yes, the height is the same but it's about 9" wide and 12" deep to fit all of the control and variable load resistors required. We are also using the same enclosure for the 1999-2003 Prius chargers. One enclosure for two products will reduce our costs - we will pass this savings to customers. :)
  11. Power350
    Bonham, TX
    Hello again, I have a question. I plugged my charger in last night and it instantly read 250v and 0 ma, is that what happens when it is in the balancing mode ? Because the night before (first time use) I plugged it in and it was at 238v in the morning. it was had gone from 227 to 236 before i went to bed. i unplugged and drove to work and then back (150miles). got 4 mpg more! Then last night it does this 250v thing. now, i reseted connections and it said 239v and some ma for a split second and went to 250v. I assumed this was the balancing. So I left it all night. this morning. I unplug ac first. go over to the charger to disconnect the d/c connector and something is poping in the charger. sounds like from the d/c connection so i hurridly remove the connector. When i go to start the car it is dead. I lost the code(forgot to save data from techstream) but it was in the hybrid control section of techstream and said voltage isolation fault or something to that tune so I assume that my battery ecu or other component is fried. Any input? I will have to get the correct code after work today and see what died...
    UPDATE: Over the phone troubleshooting with the wife prooved the 12V aux battery is low and now after testing stuff out is dead. Lets hope that is all that died. I left the hatch up with no lights on but I guess the door open light killed the battery.
    UPDATE(08/10): The 12v battery was causing the issues with the car. It is running fine now.
    UPDATE(08/22): My charger/balancer had a short and Jeff got me a new one quickly. The new charger/balancer is working fine. Now I just need the discharger :)
    #11 Power350, Aug 9, 2014
  12. jeff652
    607
    624
    Idaho
    Oh no sorry to hear you are having troubles! I just got out of bed and saw your note. We've sold close to 50 of these so far and this is our first reported issue :-(. I'm messaging you my personal cell phone now to offer my assistance.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Looks like an excellent and timely product.
    One product I would make to use with your charger system is an additional plug that has a break out harness on it. This break out harness would just connect to your existing charger lead.
    Then the owner could use this Hybrid Battery breakout to connect to a 200V Input Inverter for Hurricane use. Many Prius owners have used the 12 volt for Inverter use but are power limited. There is one owner here using a 200V input Inverter directly to the battery with excellent and high current results.
    If you can't interface with your charging connector (wrong side of relay I think or cable may not be big enough current wise) you could sell a companion break out harness to install on the battery at the same time your in the battery box. Would make it alot more attractive to get into the battery box and a very good return on that effort. This companion breakout could be a small mountable box with a (if you want to get sexy) switchable breaker in it with a big terminal strip and a cover. Throw the breaker to hook up the wires to your inverter. Or maybe just a pull out breaker like they use for air conditioner disconnects. I would be interested in that myself. That would be a seller I bet especially if another Hurricane is coming.
    The time consuming part is getting into that battery box.
    Good luck!!!!
  14. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    I am confused if this is something built-in or not.
    I guess Ed is saying we would need to install some (safe) leads to the HV battery and once in a while hook up the device for a HV battery refresh each oil change or similar schedule. The question would be total cost of installation for the leads etc.
    I will be a candidiate to try to keep my 2006 running well. I am thinking Gen3 batts are lasting longer than Gen2/2006 HV batts, but if I am wrong about that, there will one heck uva lot of Gen3 candidates.
    I think Ed is probably on the right track for the future of hybrids, almost hard to not get a hybrid when one considers their utility as back-up power. Although I leave it to the experts if hooking directly to the HV batt is the "way to go".
  15. edthefox5
    10,096
    4,833
    Clearwater, Florida
    I'm saying if you bought one of these chargers and are already going through the hassle of getting into the battery box to install there charging lead might as well make the most out of it and install another lead that you could use for a 200 Volt Input Inverter.
    I didn't look at there install pics that closely but looks like there on the battery side of the relay for there charging purposes. The Inverter breakout would go on the car side of the relay.
    These guys could offer a 200 volt break out box with a breaker and cover and easy and safe terminal strip to install the Inverter when needed. That way the Inverter needn't be permanently installed in the car ala Bob Wilson.
    Car stereo stores could offer this breakout as an install too to Prius and Insight owners.
    May be a life saver someday. The 200 volt input Inverters are the most efficient and capable of very high current loads.
    There expensive but if your out of power for 3 days you'll spend anything to get the lights back on and this Inverter can run a little wall shaker ac unit too. And for camping would be awesome.
    Cant remember the name of the Prius owner who uses one. I'll have to search the forum later. But 200volt Inverter is the way to go.
    #15 edthefox5, Aug 10, 2014
  16. edthefox5
    10,096
    4,833
    Clearwater, Florida
  17. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have a 240 VDC / 120 VAC inverter that I can connect to the HV Battery with a fused cable with a quick connector that I leave connected to the battery end.
    Personally I would prefer the specific, fused cable that I have with the quick disconnect. I would not want to modify a HV Battery Charger cable to use with my inverter.
    That is two totally different applications to me.
  18. Patrick Wong
    18,200
    6,500
    It might be OK to have the inverter power cable serve double-duty as a battery charger cable, but the reverse would not be true. Typically the inverter power cable will utilize a much larger wire diameter to handle the current being drawn by the inverter.
    Then there is the question of which side of the system main relays the inverter power cable should be connected to, as Ed mentioned in his post.
  19. jdcollins5
    5,131
    1,346
    Wilmington, NC
    True about the cable size for the inverter. My inverter cable is on the downstream side of the main relays so the car has to be Ready in order to use the inverter.
    I would think you would want the battery charger connected directly to the battery with the main relays open.
  20. jeff652
    607
    624
    Idaho
    Great ideas. I could use the Prius for camping in my travel trailer instead of buying a 3000w Honda Generator. Very clever! I like your idea about making a simple harness to install at the same time as our charger that any 200 Volt Input Inverter could plug into. We have a couple other fun Prius specific products in the works but I will look into this one as well :)
    We are starting the R&D process for the 2010+ Prius car harness as well. Stay tuned for updates on adding the third generation to our product line.
