Traction battery remaining difference between Toyota app and MID
Discussion in 'Gen 5 Prius Main Forum' started by Peter3232, Feb 24, 2024.
  1. Peter3232
    Peter3232 Member
    102
    42
    NY
    2024 Prius Prime
    SE
    Hi everyone.
    I recently picked up a 2024 Prius Prime SE in supersonic red and I am very much enjoying the car so far.
    I have a quick question about traction battery percent remaining values across two separate platforms. When I went to charge the traction battery this mornin, the MID displayed 39% charge left, but when I received a notification via the Toyota app, it stated that I had 63% left.
    This seems odd to me, just because I’d expect both platforms to report out the same value. Has anyone experienced anything similar?
  2. HacksawMark
    HacksawMark Active Member
    442
    287
    Oregon
    2023 Prius Prime
    XSE
    The percentage shown in the MID display is your available EV only percentage before it switches to HV mode, whereas the the percentage shown in the app is the total percentage charge remaining in the traction battery.
  3. Peter3232
    Peter3232 Member
    102
    42
    NY
    2024 Prius Prime
    SE
    Interesting, so the MID and app are supposed to show different values, displaying either the available or total capacity, respectively. That’s really good to know, thank you!
  4. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    Software is hard... Toyota is better at building cars than building software... Some people have returned their Gen5 because of all the software bugs. Hopefully if you're patient these problems with get fixed via updates.
  5. Zyrian
    Zyrian Junior Member
    40
    26
    ATL
    2023 Prius Prime
    SE
    I put in some time trying to figure out what's going on with battery percentages and actual kWh used, even got Dr. Prius app with the OBD device to get some real numbers, so here it goes.
    MID obviously goes from ---% to 100%, App goes from 30% to 100%. Actual 13.6kWh battery capacity and where we are at with these numbers is a little different.
    Dr. Prius usually shows around 14% when MID is at 0% / app at 30%, but when full Dr. Prius shows 91%. Mathwise it all adds up. Toyota reserves top 9% of the 13.6kWh for longevity reasons (and probably to be able to use traction battery for braking when at full charge), and about 14% on the bottom for hybrid operations. So we have about 10.5kWh available for charging / EV only use. Give or take 10% of MID per kWh.
    App is only useful for checking if the car has finished charging, honestly. I hope they update / fix it to at least match the MID, so I encourage everyone to write a review on the App Store.
    Another noteworthy thing - kWh charged reported by the app are way off. Best theory I heard is it assumes old Prime's battery size. So if you see 7kWh charged in the app (usual for 0-100%), it actually means 10.5kWh, but that's not what your power company will bill you for. On a 110V outlet you'll burn 13.5kWh for a full charge. L1 has 25%+ overhead for heat / etc.
