Traction Battery Replacement - Worth It?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Crow Rebellion, Dec 22, 2019.
  1. Crow Rebellion
    Crow Rebellion Junior Member
    Hi all,
    I've read some mixed things about replacing the traction battery, and wanted to get some advice here.
    I bought a used 2011 GenIII Prius a few years ago and it was great. Looking at the battery indicator, it seemed like the third bar was worthless (it would appear faster than the other bars but would also disappear very quickly when driving purely with the electric engine) but otherwise the battery seemed to have some good lasting power and it was working as advertised.
    Now we're a few years, maybe 20,000-30,000 miles later, and a period of about five months where the car was only driven briefly for once a month. Now the third, fourth, and fifth bars on the battery indicator seem to be flakey. They'll largely take the amount of charge that would be expected, but when discharging it'll seem as if there's amazing staying power... and then it's like I suddenly go from a near-full battery down to only two bars and the gas engine is kicking in to charge it all.
    I also have a new commute route, which makes it difficult to tell if there's truly been a hit to performance. Under this new route I have to drive up a little mountain and then go down the other way, all of which usually fully charges the battery (and frustratingly results in almost purely using the friction brakes on the final descent). Yet on the way home it's crawling freeway traffic, a 3.5-mile jaunt that takes about 40 minutes, and the gas engine kicks in 1-2 times during that crawl.
    While the battery seems to be lasting for about the distance I recall Toyota rating it for (if you were to travel purely on the electric engine), it all gets me wondering if a battery upgrade would be worthwhile. That way I could recover more charge going down the mountain instead of wasting it at the final descent, and perhaps I could handle that freeway slog without needing to use the gas engine at all. I like the look of something like the BeeMax upgrade pack, but they mostly talk about improved handling and performance, not so much improved mileage. I've read some other comments that the computer system in the Prius might utilize even a higher-capacity battery in such a manner that you don't get much benefit from it for MPG improvement, either.
    So... what do you all think? The other thought weighing on me is that I'd like to swap to a fully electric vehicle in about two years; much as I hate to burn gas while at a standstill or a crawl, maybe I should just live with the current battery as it is, even if it's not as healthy as it once was, save the money, and put it toward that electric vehicle when the timing is right.
    49,478
    there is no better battery than a new oem.
    that being said, you may be oversensitive to the display, and possibly your battery has many years of life in it.
    in any case, i would not replace it without some serious testing with tech stream. you don't have dash lights, so the computers still consider the battery to be sufficient, and you don't usually lose mpg at that stage of health.
    otoh, you're driving a gen3 which is prone to egr clogging and head gasket failure. that's where i would invest my money.
    davecook89t likes this.
  3. Mendel Leisk
    38,718
    How many miles on it?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    I think this makes sense.
    No point in replacing the HV battery before you NEED TO.
    It will be pretty obvious when it really goes bad.
    And I think the "signs" you are noticing might not be an indicator of battery capacity at all.
    There are too many factors that dictate the amount of time on battery versus on gas in a conventional hybrid.
    You might want to accelerate your savings plan just a bit though.
    It could fail tomorrow.
    dubit and davecook89t like this.
  5. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    You don't really have an indication that the current battery isn't "as healthy as it once was." The dash display is only a general indicator of what the battery is doing; you need a Scangauge, Torque app, or Techstream to see what the % state of charge is at any time with any degree of accuracy. You don't mention any warning lights, so I assume there are none. Taking all that into consideration--why replace it? Especially if you're planning on moving into a new EV in two years, save your money for that.
  6. mikey_t
    mikey_t Active Member
    370
    391
    Los Angeles
    How many miles and what state are you located? Some states have a CARB warranty on the battery, which covers it for 10 years / 150k miles (whichever comes first). If it dies and you're under that warranty, the dealership will give you a fresh one on the house.
  7. Crow Rebellion
    Thanks all for the replies. I'm somewhere around 85,000 miles at this point - it was getting a lot of miles initially but we've since moved to a place where distances are shorter (but traffic is a lot worse).
    It sounds like it's not worth it to bother with the battery, particularly given future plans. I'll hold off, then. Thanks for the input!
  8. rmg
    rmg Junior Member
    Romania
    I am in the same situation and I am thinking of different solutions.
    One of the solutions would be to make myself a battery from batteries made of china type C, which have 1.2v and 2000-3000mah. It means about 168 batteries, which is somewhere around 300usd at home. It would be just sticking and creating the 202v package needed for a Gen3. Do you think it's silly?
    I have the feeling that something like this was done by the Enno, with the aftermarket batteries for hybrids (the cylindrical batteries you see on the net). What I don't know is if the original and Enno batteries contain some control or management circuits inside each cell.
