Traction Battery size
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bmlw, Feb 25, 2012.
  1. bmlw
    bmlw New Member
    Port Orchard, WA.
    New member here, Bought a new 2011 Four Prius last September. So far my worst actual mileage has been 48MPG and my best 56.5MPG. I use the car as a commuter car all around Puget Sound Washington. I have been reading about the different Plug in conversions but they all require Plugging in to recharge. How about replacing the existing OEM battery 1.8KW with say a 4KW battery pack that will get charged with REGEN and from the Engine. Then I can take my long highway trips and do all my in town driving on the batteries. Finding a plug in location at a hotel seems to be problematic.
  2. fuzzy1
    10,515
    Unless your commute takes you across Stevens Pass -- unlikely from your location, on the opposite side of the Sound -- a larger traction battery cannot help your MPG. The extra weight will actually hurt it a bit.
    Installing a plug-in kit, without plugging in, defeats the entire purpose of the kit. Unless you displace gasoline energy by actually plugging in to get some of your energy from the electric grid, the kits are pointless. And I believe useless as well, as they still can't use regen to recharge the plugin batteries.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    To put it simply it uses more fuel to charge the battery than you'd gain in electric propulsion. As others have said, there is also the extra weight, extra costs for minimal gain.
    The plug in Prius is a plug in as grid electricity is cheaper to charge the vehicle than burning petrol to charge.
  4. rsg
    rsg Member
    64
    Harrisburg, NC
    In addition to what others said (the extra weight will negate any gains and probably hurt overall MPG), you really won't gain any additional battery travel time. Remember, at 30 MPH, you may be able to get 6 to 10 minutes (maybe more) on battery before the engine fires up to charge it, but the engine will have to run longer to charge to capacity (in the absence of any regen braking, etc).
    Thus, there's really not much benefit to the larger battery. Toyota has engineered a nice compromise between battery capacity, weight, and charging system requirements to tweak the greater number of MPG for all driving conditions.
  5. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    You would expect the Toyota engineering to be designed to cover most situations. I'm guessing that there may be driving situations for some people where they frequently hit the charge limit of the HV battery while also frequently draining to the lower limit. For them, having some extra battery capacity may help?
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Any one who lived atop a descent of over 600 vertical feet (200 meters) would in theory capture more energy at the beginning of their drive and deplete it at the end. The OP lives in a city named Port Orchard, a surprising number of ports are at sea level. There are low hills south of Port Orchard, but nothing that would fill the HV battery. The Cascades are not close, but the are the closest range s/he may need to get over.
  7. babybird
    babybird Member
    117
    44
    Colorado
    The other problem with running a larger capacity traction battery is you'd also have to change the way the computer operates with it. If the traction battery's state of charge drops down to around 53%, it changes the way the ICE runs-- higher RPM and less torque to the wheels so it can charge. As the SOC drops even lower down to around 46-48%, it enters a "panic-mode" that increases that effect. Your mileage drops quite a lot regardless of your driving in that scenario, and with a higher capacity battery, it would spend a lot more time running in that mode.
    Conversely, when the SOC on the traction battery gets up around 70%, it enters an electric-rich mode in which the ICE runs at a much lower RPM and the traction battery provides a lot more of the drive torque to the wheels to improve mileage. That's why the plug-in conversions work so well-- because by being just an external power source to keep the factory traction battery at a high state of charge, the hybrid system gets to spend a lot more time in its most efficient state of operation. But the benefit only really works during the electric operation, and would be negated by having to recharge the extra battery capacity. By the time you convert battery voltage to MG2 voltage, then convert that to motion, then convert the motion back to electricity through MG2 and convert that back to battery voltage (or gasoline energy through MG1), you're only gaining something like 37% of the spent energy back. The rest of that energy is all lost to the various conversion losses along that path.
    I read in a thread a long time ago (don't remember if it was here or cleanMPG) about how Prius gets such great mileage. It went something like this: Drivers of normal cars get poor mileage because they waste 100% of the energy to get them moving every time they stop. Drivers of the Prius think it gets better mileage because of its regenerative braking recapturing some of that lost energy every time you stop, and using it to get you going again. Hypermilers get the incredible mileage they get because they drive differently, and don't use the brakes much at all if they can avoid it. There was a proverbial quote about those hypermilers where their dominant driving philosophy is, "Prius has brakes?" Regenerative braking is better than no regenerative braking, but no braking at all is even better than regenerative braking.
    Plugging in to the wall will always be more efficient than regenerative braking because it eliminates one set of the conversion losses in a hybrid system like the Toyota's HSD.
