Traction contol light comes on at low speed braking
Discussion in 'Gen 2 Prius Technical Discussion' started by yzfrider2001, Mar 17, 2014.
  1. yzfrider2001
    yzfrider2001 Junior Member
    23
    My wife just called and told me that while braking (at less than 15 mph) there was a slight thud and the traction control light came on. She is at work now and I won't get a chance to look at it and test it until later today. Any ideas? Thanks in advance!
  2. Patrick Wong
    18,200
    6,472
    1. Check tire inflation pressure.
    2. Check tire tread depth.
    PriusGuy32 likes this.
  3. JC91006
    16,479
    8,397
    she might have gone over a speed bump (at a higher rate of speed) or an uneven surface on the road. That will normally happen when that occurs.
  4. Alesf76
    Alesf76 Member
    89
    33
    Italy
    Right, this is what happens when braking and the same time hitting a deeper than usual hole or higher than usual bump: the wheel looses traction for a fraction of a second like when on an iced paddle so ABS is engaged.
  5. bisco
    49,430
    polar vortex, should be fine by june.;)
  6. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    bisco: Sometimes your inane posts are funny.......but mostly just stupid.
    Add to the list of things that might have happened:
    While lightly braking, ran over a paint strip or large tar snake in the road. Those things can be quite slick if damp or cold. Or maybe hit a patch of oil/grease dropped by another vehicle.
    Or maybe you live in the part of the country where there is still ice on the roads in places.
    When the ABS cuts in momentarily, there can be a disconcerting clunk.
  7. bisco
    49,430
    thanks man, i'll try harder.(y)
  8. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I had exactly the same thing happen just after I braked for a speed-bump (painted, and slippery) in the complex where I live. The light only flickered on for a moment, and I'd noticed it happen before when I did a hill-start, and I drove over a wet/icy man-hole cover. No clunks but I thought it might be the ABS system getting a bit enthusiastic.
  9. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    That sounds like normal behavior. If a front tire hits a bump while braking, it'll often activate the ABS. The ABS and traction control share that same, yellow light.
  10. yzfrider2001
    23
    Thanks for all of the replies! Ice isn't present here as it was here in Parris Island, SC. I found it odd that this is the first time it has ever happened after two years owning the car. I quizzed her on bumps, etc., but she said she didn't run over any (she is pretty sharp in that area). The only weather conditions was that the road was wet, but its the same route she has been driving since we have been stationed here and have encountered similar conditions before. So, I will just chalk it up to an odd occurance. Now if I can figure out how the gas gauge went from half to one bar in less than five miles...
  11. don m
    don m Junior Member
    meadowview va
    none of this happened to me.A speed from 55 to 65 smooth rds. no braking will not excelerate
  12. bisco
    49,430
    hybrid battery going south?
