Traction Control and wintery conditions
Discussion in 'Gen 2 Prius Technical Discussion' started by ctbering, Jan 8, 2009.
  1. ctbering
    ctbering Rambling Man
    1,650
    123
    Chicago Illinois
    I copied this from one of the consumer sites. Is this an actual Prius engineering a problem inherent with the Prius drivers who live in snowy areas?
    Two weeks ago, I drove through an ice storm and thought the traction control saved my life. Many cars, trucks and vans literally slid in ditches, a few slid on interstate concrete dividers and a few slid into the barriers. I made it to work that eventful day unscathed but this report is concerning. I drive a 2008 Prius. Is the car safe with traction control, as is?
    Winter Weather Warning for Prius Drivers
    Traction control shuts down engine on slippery conditions
    One year after first reports in ConsumerAffairs.com that the Toyota Prius traction control system can fail to operate properly on a snowy road, Prius owners report the hybrid’s TRAC system is still inadequate on slippery inclines.
    One Vermont Prius driver, suffering through a recent January snowfall, described Toyota Prius traction control as "dangerous in mountainous snow country.â€
    The Vermonter wrote that the “system is flawed and should definitely be modified. In marginal traction conditions, such as Vermont winters, the Prius traction control system will shut down power to the drive wheels and prevent forward movement.â€
    In January 2007, ConsumerAffairs.com reported the traction control failure in the Prius as one of the oddest Prius stories on file.
    "When my car is on any kind of slick surface that causes one of the front wheels to slip, all power to the drive system is stopped," wrote Christopher of Reston, Virginia.
    Traction control failure in the Prius is no longer a isolated event. The continuing failure is producing damaging results.
    A Langley, Washington Prius owner told us that her hybrid this month “stopped totally on a medium uphill approach to her driveway and garage resulting in the car falling off (the) driveway into ravine of trees†on a snowy December day.
    In Medford, Oregon, Mike is the most recent victim of the reluctant traction control system.
    “I am a seasoned driver in the snow. I can drive front-wheel drive, rear-wheel drive and four-wheel drive. I am a forester and have been driving in snowing conditions for 28 years, 22 of those years on the job," he wrote. "I just had my first experience driving my Toyota Prius in the snow today. The engine cut out all power anytime the wheels slipped at all.â€
    "Very dangerous"
  2. bwilson4web
    15,524
    Nope, you died and everything since then including this note is just an illusion. <cue Outer Limits music>
    You have a choice between your 'lying eyes' and what "Joe Benton," a notorious hybrid skeptic wants to claim. He is a nut case and spends too much of his time trying to find something wrong with the Prius. That is the role of a propagandist.
    If you think your car is unsafe, wait for the next winter storm, find a parking lot, and see if you can make it misbehave. But good, bad or ugly, the only thing that one can count on from Joe Benton are Prius skeptical reports.
    NOTE: I'm sorry to be so harsh but "Joe Benton" and ConsumerAffairs has gone over the top and sad to say, he provides the nonsense you quoted as fact. You've come to PriusChat, one of several fact based web sites and soon folks will offer you experience backed up by real world driving. "Joe" cherry picks his reports and he really is doing nothing but instilling FUD (Fear Uncertainty and Doubt.)
    You've already survived an ice storm without death, dismembership or an accident. To make sure things are OK, use the next storm to find an empty parking lot and see if you can make it 'misbehave.' Use experiments to find the limits. As for "Joe" and the fear mongers, that they might have led you to ask here is the only good thing. There are several other excellent hybrid web sites and Yahoo groups that have unbiased accounts from actual Prius experimenters that many of us also participate in postings. Although Consumer Reports are not fans of the Prius, at least Consumer Reports is reasonably fair, honest and factual.
    If you'd like to have some fun, go to ConsumerAffairs and file a complaint about Joe's article that you quoted. Point out that you survived an ice storm and didn't die. That the claims of the article you quoted turned out to be false. Then notice at the very end, he asks if you do NOT want to be contacted by a consumer attorney. I believe he is a 'land-shark' looking for profitable companies to sue. <GRINS>
  3. icarus
    icarus Senior Member
    4,884
    976
    earth
    People who complain about the traction control system either don't understand how it works, or have bad tires, or bad driving skill, or all of the above. I will say that if you live in a very snowy climate , real snow tires are a great idea.
    Icarus
    PS. It is like the skid marks in the slick ice I saw the other day,,, all four wheels locked for 200' as the car missed the corner and when into a deep ditch. Just getting off the pedal and STEERING would have prevented a pretty serious crash. 1/2 mile away, another set, heading right into a utility pole! Operator error in both cases!
  4. Tideland Prius
    16,158
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    Consumeraffairs.com ≠ Consumer Reports
    Consumeraffairs.com = rumor mongering lawyers trying to drum up business
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The traction control system does have its flaws, mostly in that it is a bit on the conservative side and tends to cut power very quickly. With good tires it works fairly well, but will undoubtedly be better on the new model.
    That said, the driving situation you describe is an issue of VSC, not traction control. VSC, or Vehicle Stability Control, works to keep your car under control around corners and in slippery conditions. The VSC on the Prius works very well.
    As previously stated, the web site you reference is full of baloney or some such similar substance.
    Tom
  7. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
  8. djg12
    djg12 Junior Member
    N.H.
    I was concerned about the Prius in snow after reading a lot of the posts on problems with the traction control.
    I live in NH and drive to Boston each day for work, sometimes in some scary stuff. My driveway has a slight incline, enough to stop lots of vehicles if not cleaned off properly. At the end of my street there is a hill with a stop at the top.
    So far, the Prius has not disappointed. In a snow storm it got up the hill on the street with the traction control light flashing but it kept on going and I had no issues. I guess it could be equivalent to driving on very soft beach sand, go slow and keep going.
    Anyhow.
    As many have said good snow tires are a must, likely with any front wheel drive vehicle. I have Nokian Hakka R tires on my Prius and love them....they are the best....turns the car into a SUV!! (just kidding!):D
  9. richard schumacher
    7,663
    1,038
    United States
    Any car with traction control benefits greatly from snow tires when driven on snow and ice.
  10. bac
    bac Active Member
    863
    52
    Pennsylvania
    Complete rubbish, and propaganda for those who really don't understand how traction control works in ANY auto.
    It reminds me of the early days of anti-lock brakes. People didn't, and many surely still do not, understand how they work. This lead to foolish statements about this technology also.
    The Prius traction control works the same as in ALL autos. Want better traction control? Buy better tires. It's the same story with every car. End of story.
    ... Brad
  11. Boo
    5,051
    483
    97
    Flushing, NY
    The main problem is the lack of an on/off switch. If you lose power going up a slippery incline (which does occur as noted in the article), the problem would be solved by being able to turn off the traction control.
  12. qbee42
    18,058
    3,074
    Northern Michigan
    Close, but not quite correct. It is true that most of the comments against traction control (and VSC) are misinformed rubbish. That said, not all traction control was created equal. The traction control on the Prius simply limits torque to the drive wheels when slippage is detected, and it does so in a fairly aggressive manner, especially at very low speeds. More advanced traction control systems will apply a brake to a slipping wheel, allowing torque to transfer to the other drive wheel. Toyota's FJ40 will do this, but not the Prius.
    As another note, let me add that the traction control on the 2006 Prius and newer is vastly better than the 2004 and older. Some place around 2005 a new algorithm was implemented which allows for more wheel spin.
    Tom
  13. jsdigger
    jsdigger New Member
    seattle
    I have a 07 prius,after driving around in area for a few days i wasnt too happy with trac control,unfortunately because the engine to generator(dampner)dosnt have any way to absorb large amount of torque when it does get traction.there is no way to turn trac control off,its a safety feature so you dont damage anything,i think that is why conventional vehicles handle beter.the prius gets parked and the subaru outback gets to have fun in the snow.sorry but the prius isnt the best car for snow but it still does pretty good if you know what your doing
  14. Worknclassbug
    Worknclassbug New Member
    Huntington WV
    The VSC works amazingly well on my '08 Prius but the traction control is way too aggressive. It will only let a tire spin about 1/2 a revolution and power is chopped completely. I do wish there was a way to disengage the system. Sometimes you have to have wheel spin to get moving on snow or ice. The Prius would be better in my opinion if it didn't completely chop the throttle before it tries again. What little bit of momentum it has achieved before the slippage is lost when it throttles back too much.
    My wife's parents have an inclined driveway. The Prius sits at the bottom and we have to walk it while other members of her family with front wheel drives make it up just fine. They do spin but they keep their momentum enough to make it to the top. I just wish there was a way to turn it off like I can on both of my Fords. Even my '04 Mustang GT doesn't completely chop the throttle and allows it to gain momentum with the traction control on. In some situations it has done better than the Prius although I feel much safer in the snow in the Prius by far...
  15. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Must we remind folks that the BASIC traction control is to prevent motor/generator overspin? A spinning tire that suddenly catches some traction can cause MG1 (starter/generator) to quickly exceed it's max RPM if the engine is operating at any significant RPM.
    Toyota did detune it a bit in 2006, but only to a limit to which they felt PSD damage risk was minimal.
    I've said it before, but I'd rather need a tow out of a temporary mess than a multi-thousand dollar hybrid system transaxle repair caused by an attempt to climb a slippery slope.
  16. Worknclassbug
    Huntington WV
    It's an acceptable quirk for me no matter what the actual reason for it is. The Prius is my wife's car. I like conventional cars so I have one. I'd rather my wife stay away from situations that I would normally turn the traction control off on my car since I don't think she has the skill needed to spin her way up an ice/snow covered road anyhow. If she could turn it off, the car would probably end up in some ditch somewhere. I'll take it as it is and be happy with it but it would be an irritation to me if it was my daily driver and part of the reason I don't have one for myself...
  17. 2001red
    2001red New Member
    Minneapolis
    I have a 2008 package #5. I replaced my tires before the winter season with MXV's. I live in Minnesota and the car is excellent in the snow. Each vehicle is different. This car is safe and has excellent traction and control. Drive carefully and know your vehicle. I see many SUV's off the road on icy days.
  18. Worknclassbug
    Huntington WV
    I agree. Ours would probably be better with a different set of tires. It's a 2008 and has whatever came stock on it.
    After you get moving the Prius does fine unless you lose momentum. You guys have to remember that I'm in the WV mountains and most of the time you are either going uphill or downhill...LOL. Like you said though, each car is different. My Taurus wont get moving on the ice/snow unless I get the tires spinning and saw the wheel back and fourth and my Mustang is just the opposite. Spinning the tires does nothing for it since it has a limited slip rear end. It just starts going sideways. I have to get the car rocking by just bumping the clutch to get it moving.
  19. Oddest_raindrop
    Oddest_raindrop New Member
    75
    wisconsin
    I personally don't mind the traction control until I and really stuck. Regular driving down the road is fine. However I do understand the problem with turning it off. What I was thinking... like it matters now... is that if could have had a setting say 1 - 10 allowing the driver to increase the aggressiveness of the system. Also say if it gets to far into one way the gas engine would be require to be on and at x rpm to not cause harm to the HSD. This would seem like a fair compromise. I know it's not going to happen. But one can dream.
  20. The Bigyun
    The Bigyun New Member
    Whitby Ontario Canada
    My 09 with traction control has been very good in heavy snow this January and February. Have been driving with normal tyres on six inches of snow with no problem. I have not experienced any of the conditions mentioned by others.
