Traction control drops transmission out of gear
Discussion in 'Gen 3 Prius Main Forum' started by PriPriMan, Sep 17, 2010.
  1. PriPriMan
    PriPriMan New Member
    WA, USA
    I've had my 2010 Prius since June and it has a problem at very low speeds that seems to be getting worse. The problem is that if I'm driving very slowly, like when pulling into a parking space, and I brake gently, the traction control light starts flashing and the transmission drops into neutral. At that point I can't shift into any gear unless I put it into park first. This happens when moving very slowly in either forward or reverse and on completely dry pavement. I called the dealer and they hadn't heard about this. Has anyone here experienced this?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    686
    Eastern Oregon
    I have not heard of anyone who has had that problem. Make sure you are not pushing the brake down to far because that activates the hill-start assist function, that will cause the traction control light to flash. Owner's Manual page 243.
    If it is not the hill-start assist and if it is repeatable you should have no problem getting the dealer or Toyota interested in fixing it. The biggest difficulty people have with warranty work seems to be problems the dealer's mechanics can't duplicate. If they can't see it happen they don't want to believe it happens.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,757
    47
    South Yorkshire, UK
    PriPriman said he was braking gently, which wouldn't put the hill start assist into action and even if it was the hill start assist coming on then that wouldn't put the transmission into neutral.
    I'm thinking traction control sensor communication problem, probably the front wheels as it's related to the transmission.
    First thing I'd do is get underneath and check the connections to the front sensors, they should be on the hub carrier somewhere.
  4. PriPriMan
    WA, USA
    I did some more testing on this and it seems the problem occurs if the car rocks back and forth even slightly while it's stopped in gear with the brake applied. For example, if someone gets out of the car while it's stopped in gear just the slight shaking of the car when they get out causes the problem to occur. It seems to happen more on an incline, even a slight one. It's still under warranty so I'm taking it to the dealer.
  5. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,280
    343
    Pittsburgh, PA
    Hmmm, I never had this problem when I had a 2010...
    I know in the Gen.II, the traction control is VERY aggressive. If I could rate the traction control on the Gen.II on a scale of 1-10, i'd rate it an 11. I thought traction control was one of the things they improved with the Gen.III...
  6. Skoorbmax
    Skoorbmax Senior Member
    2,641
    263
    Western NY
    Haven't heard of this problem. TC _taking you out of gear_ and requiring you to stop to get it back in is definitely not cool.
  7. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    I do not understand why people just call the dealer :confused:
    Take it in and show them
  8. PriPriMan
    WA, USA
    I called the dealer because they are a ways from where I live and it's pointless to take it in unless I can demo the problem, otherwise it's just a waste of time. I called them to find out if this was a known problem and they had a fix. It wasn't so I needed to first figure out how to show them the problem, which isn't obvious.
  9. Bob Comer
    Bob Comer Active Member
    708
    451
    South Carolina low country
    I just got a new Gen3 Prius V last week and when parking the traction control light does come on occasionally, but it never kicks me out of gear. It does take hitting the accelerator a little harder to get moving again though...
  10. andino
    andino Senior Member
    746
    546
    San Jose, CA
    ^^ You're activating the Hill Start Assist
    To the OP, does it happen often? Maybe attempt to duplicate the situation and see if the problem arises again. If you can, take it to the dealer and replicate the same thing.
  11. Paradox
    29,111
    8,586
    201
    2014 Prius v wagon
    Ditto, you're pressing hard enough on the brake to activate the hill start assist feature. Look it up and read about it in your manual...
  12. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    I don't think I've ever activated the hill assist. Don't even know if it works. Guess I should check although I doubt I would make a trip to the dealer if it didn't.
  13. Paradox
    29,111
    8,586
    201
    2014 Prius v wagon
    If when you brake you press hard enough at a low stopping speed, such as when parking, to make it beep and light up a yellow light on the dash and then you have to give it some bit of gas to make the car move, the hill start assist has been activated. You can easily try it out. Next time you are stopped, say at a light or a stop sign, press all the way down on the brake. You;ll hear the beep and see the yellow light. Then when you take your foot off the brake the car will not creep forward until you give a bit of throttle.
  14. jburns
    829
    111
    Archdale, NC
    Thanks. I know how it works just never checked it or see the need for it. I guess I just press hard enough to stop. Maybe if I lived in San Francisco.
    In response to the bolded part why would you take your foot off the brake unless you were ready to move?
  15. Paradox
    29,111
    8,586
    201
    2014 Prius v wagon
    Sorry, I was explaining how it works and how to activate it. No harm, no foul, at least you know it's there in case you're on a hill and need it for some reason. I've used it maybe once because someone stopped quite close behind me on a moderate incline.
    I was describing testing it so you know how the system worked/felt if you were on say level ground. If on a hill you will not roll backward before having time to step on the gas. On level ground the car will not creep forward until you give it gas. Giving it gas is what deactivates the system; Well that or enough time off the brake and the system cancels out.
    Ok, I'm letting this thread get back on track now lol :focus:
  16. Bob Comer
    708
    451
    It was once at a stoplght and twice in the same parking lot, I thought it was pretty light breaking but I'll watch fo it, thanks.
  17. Bob Comer
    708
    451
    I tried what you said and I got it to go into hill start assist quite easily, but the traction control light blinks instead of being solid on like what I described before and I know I didn't press the brake that hard before.
    It hasn't happened again yet, so I'm not really worried about it anyway.
    It rained heavily today and not a peep from the traction control so I think everythings working as it should.
  18. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    ive never had the traction control turn on in me, even when i floor the car. the fact that there isn't even a switch to turn it off is mildly hilarious. id just take it to the dealer. i doubt you are activating hill start because that requires pressing the brake ALL THE WAY to the ground. and people dont do that hwen they are trying to park.
  19. 2k1Toaster
    5,982
    3,781
    Rocky Mountains
    Could be a faulty sensor somewhere that is being over zealous. If you can honestly make it shift into nuetral by having someone jiggle your Prius while in Drive, then there is an issue. I don't know what, but it is there. Could be a sensor plug not mated the whole way or it could be a domokun stowed away inside your Prius on the boat ride over here and ate a wire, who knows.
    As for traction control, there is a super secret handshake type method to turn it off (at least in the Gen II) which is useful in heavy heavy ice/snow. But the big danger is that the combination of MG1/MG2/ICE can produce more power than the PSD can handle if it slips potentially causing damage. A little here and there, but if you had a switch and drove with it off, you could destroy your car in a year or two perhaps.
    My vote is for the domokun...
Loading...
