Traction Control lights in sharp left turn
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bwilson4web, May 5, 2015.
  1. bwilson4web
    15,561
    So four lanes, divided, with a left turn lane, five lanes at the intersection. I'm down ~15 mph, maximum turn speed and one car is just clearing intersection and and +100 yards from next approaching slug of traffic. Keeping the speed, I make the left turn confident no problem then halfway through turn:
    • feels like a soft tuck
    • traction light flashes
    • already to straighten out
    • everything normal
    This is the second time I've seen this in a year. Pavement dry, 48 hours since last rain; ~8:00 AM so rush hour is on. Before doing some parking lot tests, anyone have a clue about how to replicate?
    Sad to say, my dashcam SD card did not play. <GERRRRR>
  2. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    People have reported this while executing U turns.
  3. RightOnTime
    RightOnTime Senior Member
    755
    1,625
    183
    Kidnapped in OC, CA
    From my experience, any slight wheel spin will cause the traction control to light up.
    49,693
    tyres pressure?
  5. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    I have experienced something similar several times... I think i was making a tighter turn than you described not sure of the speed but 10+mph for sure... and the traction control activated similar to ABS on/off/on/off feeling...
    I think the traction control is triggered due the the different "wheel speed on the ground" but that is just a guess
  6. fuzzy1
    10,254
    Center differential binding up?.
    Oops, never mind. I'm reverting to typical Subaru problems.
  7. CardiffChris
    CardiffChris Member
    94
    63
    Cardiff by the Sea, California, USA
    2014 Prius Plug-in
  8. jry423
    jry423 Member
    96
    37
    Ohio
    Mine flashed while I was sitting in a drive through. Not moving at all, it flashed the whole time I had my foot on the brake while ordering, and went off when I took my foot off the brake. Only time it's ever done that.
  9. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Push the brake hard when you are stopped and I expect it will happen again. (assuming the 2015 works like the 2010)
    That light flashing when you are stopped is how you know that the hill start feature is engaged.
    This feature holds the car briefly so it doesn't roll as you transfer your foot to the accelerator and get the car going.
  10. jry423
    jry423 Member
    96
    37
    Ohio
    I didn't know that. Good to know.
  11. fuzzy1
    10,254
    Press the pedal more lightly -- 'normally' for the majority of us -- and it won't engage that feature and its indicator light.
  12. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    How many miles you have on the existing tires?
    When tires get too many miles or tread depth get thinner, the traction will get diminished and the starting losing traction when making hard turns.
  13. qdllc
    qdllc Senior Member
    1,370
    399
    These things come to mind when any wheel slippage occurs.
    1. Slick road surface/spot.
    2. Tire with low or too high air pressure (in conjunction with)...
    3. Worn tire tread/hardening compound.
    The Prius is the first car I've ever had with traction control, so I don't know how much one tire must spin over the other for it to be interpreted as "slipping" by the system.
  14. jry423
    jry423 Member
    96
    37
    Ohio
    I stomped the pedal pretty hard as I was getting my wallet out of my pocket. That explains why it hasn't happened before or since.
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    hello bob,
    on my 04, i had a similar issue when an ignition coil was starting to go bad.
