Traction control problem after new springs
Discussion in 'Gen 2 Prius Main Forum' started by qbee42, Nov 12, 2020.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    I recently had a weird problem on our 2006 Prius that I thought I might share just in case anyone else ever has a similar problem. We had new springs installed all the way around after breaking a rear spring. The work was done at the local Toyota dealer. Driving home I noticed an odd discontinuity when braking to a stop, very similar to when you hit a bump or ice during regen. I tried to brush it off as just a new feeling to the suspension, but I was concerned. Braking harder, at speed, set off the traction control light. Later I got an ABS error. Something was wrong.
    I took the Prius back to the dealer and they said that debris had gotten into the wheel rotation sensor. They cleaned that and all was good. Driving home it wasn't good. I was convinced that they had broken a wire to a rotation sensor or something like that.
    It took multiple trips back to the dealer, but they finally realized that a tone ring had been cracked while replacing a spring. It wasn't the rotation sensor, it was the toothed ring that the sensor sensed. Replacing that fixed the problem and our 2006 is back on the road.
    SFO and PriusCamper like this.
  2. PriusCamper
    PriusCamper Senior Member
    13,094
    5,309
    Pacific Northwest, USA
    Why is it dealerships are the ones screwing up repair jobs on here way more often than regular mechanics? I don't understand why Toyota puts up with it?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,000
    NJ-USA
    Don't know if it was coincidence or not. The only time I will see a problem is when the tone ring cracks because of rust forming underneath it- the rust expands as it forms and puts outward pressure on the tone ring until it pops.
    I have no idea how you would damage the ring during normal work. I would have to deliberately try to hurt it.
    Glad it's working now.
    dolj and PriusCamper like this.
