Traction Control/VSC
Discussion in 'Gen 2 Prius Main Forum' started by dagreen1, Jun 22, 2010.
  1. dagreen1
    dagreen1 New Member
    Hi all,
    I need some help.
    Yesterday I clipped a curb & sliced a tire. I put on the doughnut & went to drive home & the tration control light kept coming on & I couldn't get the car to go above approx 32mph. Luckily I was only a couple blocks from home at the time.
    This morning I tried again & by flooring it I was able to hit a blistering 48mph but only at the expense on my battery charge. Most of the power was coming from the electric motor without any recharge from the gas engine which I am assuming was being restricted by the traction control system.
    Has anyone else experienced this problem? Is there anyway to disable the traction control on an 05'?
    Thanks!
  2. Patrick Wong
    18,200
    6,479
    Did you check the air pressure in the doughnut spare? It should be 60 psi.
    You cannot disengage the TC without causing potential damage to the powertrain, so please drop that thought.
    Ideally, you would immediately buy a replacement tire. If this is not feasible, you may want to move the spare tire to a rear position so that the front axle has matching tires. Then the problem should go away.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    there is a way to disable.. but i don't recommend it. make sure you're spare is on the rear.. you'll mess up your front end eventually if you keep it up there...
    if you don't move it to the rear.... the vsc is saving your car.
    if you're up for wrecking your car.. here's how to disable;
    car on but not in ready.
    depress gas pedal 3 times.
    change to neutral
    change to park
    foot on brake.. start car into ready mode... engine should rev up instantly
    ..... unless i forgot how to go into that mode.... (then someone correct me.. it's been a while)
  4. dagreen1
    dagreen1 New Member
    Thanks for the info Patrick. I already took the wheel to get a new tire. I ended up renting a car though to get to work. Driving 33 miles on I95 at 30 mph didn't seem too appealing. I'll keep in mind the spare on the rear tip in case another curb ever jumps in front of me!
    Thanks again.
  5. tf4624
    tf4624 Active Member
    526
    51
    This is the worse car ive driven with Traction control... i say so called 08 prius
    its to damn dangerous in snow/ice weather.. car can't stop even if i put it in nutrual.. almost ran the stop sign.. I rather have abutton that turns if off like MOST of the other cars in this world.. And if toyota was worried about the motor spinning.. then fix the shit to run max 10,000 rpm or so like a normal damn motor with the option of turning traction on or off.. cause when it goes on.. I CANT stop the car.. It will try but keep slidding all over.. I rather drive another car in winter weather
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Sounds like you might not have winter or snow tires. Where abouts are you living? Is snow unusual where you live?
    Just curious.
  7. bac
    bac Active Member
    863
    52
    Pennsylvania
    When the traction control comes on you cannot STOP the car??? Geez - I have the opposite problem.
    -Brad
  8. tf4624
    526
    51
    the DAMN car just slides in the direction of where im going if im braking when the damn TC light goes orange..and u have to pump the damn breaks hoping it will work.. the shit just goes wherever, you have to hope you don't hit anyone
    toyota needs to fix this goofy shit
  9. fuzzy1
    10,237
    This sounds like my 2010 last month -- after the oem a/s TIRES became too worn for winter grip. Except that it shouldn't be using TC to stop. That is a 'go' function.
    Its single brief winter test last year was wonderful. This winter's first test was completely different (though comparisons on different days are not necessarily meaningful), and it was quite clear to me that the tires are past their prime. The car -- admittedly a different model year -- handled the little available traction very well. Its just that modern ABS/TC/VSC can do only so much with inadequate tires.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This is from the anti-lock brakes, and is common to all modern cars. Get some real tires and the problem will go away.
    Tom
  11. tf4624
    526
    51
    LOL, its got new tires on them ALL 4
  12. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    But are they winter/snow tires or normal summer tires? If you live in a warm area that doesn't get snow very often then chances are they're summer tires.
    Others will confirm how to check.
  13. tf4624
    526
    51
    All season radials
  14. fuzzy1
    10,237
    Insufficient information.
    I understand the older Priuses have not-so-good TC, though the 2008 shouldn't be as bad as you indicate.
    But can you be more specific about what is wrong with the ABS? The skimpy detail so far gives me little confidence that it is being used correctly.
