traction control
Discussion in 'Gen 2 Prius Main Forum' started by hayduke.klr07, Dec 17, 2009.
  1. hayduke.klr07
    hayduke.klr07 Junior Member
    Rapid City, SD
    Has anyone been in a situation where the your prius just stopped going due to the traction control? i was on a hill with some wet grass and a bit of mud with OEM tires. would get half way up and the car would just stop. so i'd roll back down and gave it a bit more of a go. it took 5 efforts to get it done. right now we have Hanook winter tires with studs and seems to due pretty well in the snow and ice. hoping a better all season tire will fix for summer but...almost makes me think about trading in on a Forester. not sure why there is no switch to be able to turn off the traction control. like what if a person got half way into an insection then nothing???? any thoughts out there?
  2. dogfriend
    7,512
    1,188
    Carmichael, CA
    Yes. Get some decent tires. The OEM tires are good for mileage but inadequate in every other way.
  3. northwichita
    481
    102
    29
    Wichita KS
    I had read the newer prius were improved in this regard. I have an 04, and what I've read to do is to just floor it in situations where it bogs down. Possibly it was so slippery in your situation , plus going uphill, backing up and trying again was the only thing possible that would have worked, even without traction control.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Very common with the Gen II Prius and the OEM Goodyear (lack of) Integrity tires. Better tires will help a lot.
    Tom
  5. richard schumacher
    7,663
    1,040
    United States
    Wet grass and mud? Better tires would help, but Prius is not an off-road vehicle.
  6. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    ugh ... i hate the traction control in my '08
  7. odysseus
    odysseus Junior Member
    61
    Austin, TX
    Really? Why? Are there other tires that combine good mileage with good handling characteristics?
  8. dogfriend
    7,512
    1,188
    Carmichael, CA
    Yes, there are many tires that are better for traction and cornering than the OEM Integrity tires. Some of them are comparable for mileage as well. You can search for the many threads on tires or take a look at TireRack.com for reviews on other possibilities. Nokian, Michelin and even better Goodyear tires have been discussed as better alternatives to the Integrity.
