Traction (HV) Battery Charge Level
Discussion in 'Gen 2 Prius Main Forum' started by turnbowm, Jul 7, 2008.
  1. turnbowm
    turnbowm Junior Member
    So. Calif.
    Have a 2008 Touring edition with 1200 miles on it and have NEVER seen a full charge level indicated on the MFD. The maximum charge level appears to be ~2 bars down from the top. Don't recall it being any higher than that.
    Is this normal?
    Also noticed that the battery seems to lose charge level rathjer quickly when driving around town at low speeds..... ICE not on most of the time. Battery charge level seems to recover quickly enough, however, when the ICE is on for a few miles.
    Also noticed that the car is VERY sluggish if the battery charge level gets down to two bars. I assume that all of this is normal, but thought I would ask what others have experienced.....
  2. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    the level of the battery pack depends MUCH on how you drive, where you drive, etc.. it is very rarely fully charged. We've owned ours for two years and I can't recall it ever being COMPLETELY full, though it gets to seven (?, one under full) very often.
    When you get below three bars the motor will run even faster than normal to provide gas to move the car and to recharge the battery.. best to not try to drive so much on battery and just drive sensibly, the car knows what do to
    also.. your battery is very new.. batteries are like sponges. they need to be exercised to learn to "absorb" a charge consistently.. it'll improve with time
  3. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    Everything you describe is normal, assuming you haven't yet driven down a mountain or good-sized hill.
    Drive your Prius part way up a mountain steep enough to require you to apply the brakes on the way down. A 1000-foot elevation gain should do it. Southern California has plenty of these inclines. Then, go back down in "Drive", applying the brakes as necessary. Soon you'll see 8 bars on your SOC (state of charge) indicator, indicating 80% charge. The battery can charge even higher, but you can't tell by the SOC indicator.
  4. turnbowm
    So. Calif.
    FWIW, ran across this info on another forum which is in agreement with the replies thus far.....
    The Prius is programmed to target a 60% state of charge...represented by the 6 blue bars on your display. consider anything outside of that 60% target as a energy buffer range that the car is programmed to deplete fairly quickly if it goes above or restore fairly quickly if it goes below that target.
    You'll only see a full green battery if you go down a long grade with regenerative braking to store more power. Even at full green, at most, it represents an 80% SOC...I've seen 82% 2 times in 4 1/2 years of ownership and it only lasted a few seconds. One of the primary goals the car is programmed for is to preserve the life of the battery...by keeping it from excessively cycling to high and low SOC it will do that job well.
  5. echase
    echase New Member
    227
    You can also put it in drive, floor the brake and step on the gas to charge the battery to eight bars, but that's just rude to your car.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    This is normal. A quick search on this site will show many threads discussing this topic. The battery needs to be able to absorb energy for regenerative braking as well as supply energy for electric drive, so the Prius tries to maintain a state of charge (SOC) someplace between empty and full.
    Tom
  7. prius4ed
    prius4ed Member
    120
    Irvine, CA
    ZERO Traction (HV) Battery Charge Level -- car runs fine
    My 2004 had a front end accident. I fixed the body, some severed wiring, and replaced the inverter. It sat for a few years. The traction (HV) and aux batteries died. I replaced the aux battery but the HV battery was too weak to start the car. The dealer said they tried and can't charge the HV battery (blamed a bad wiring harness and wanted $1200 to replace it). I replaced the HV battery myself and now it starts and runs fine. BUT, the MFD shows NO BARS on the HV battery!! Also, the red triangle with exclamation point and CEL are both lit. NEED ADVICE. NOW THAT IT'S RUNNING, CAN SOMEONE SCAN THIS FOR ME (NO DEALERS PLEASE) AND DO YOU THINK A SCAN WILL REVEAL WHAT'S WRONG IF ANYTHING! I LIVE IN IRVINE, CALIF (SOUTHERN CAL).
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Re: ZERO Traction (HV) Battery Charge Level -- car runs fine
    Buy a Scangauge here at Priius Shop. Pull the codes yourself plus
    it will help you get better mileage on the road.
    Report codes here. Probably HV ECU is blown.
  9. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Yup thats exactly how mine acts after 3 years too. I can get the mfd to show almost full green bar after 15 miles though. All green except missing top bar. Never have seen all bars but being a flatlander probabaly never will.
    This car is not a good choice if city stop & go only. When I commute to work on the highway I average 45-47 but when the wife drives it for a few days the mpg is down around 39 now. New tires have made it much worse.
  10. prius4ed
    prius4ed Member
    120
    Irvine, CA
    For $160, will it pull ALL OF THE CODES the same as the dealer scan tool will? I bought an OBD II scanner locally, and it would not get all the codes -- I hope this isn't the case.
    Jack -- are you available to scan my car? I live in SoCal.
  11. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    The only thing that bothers me is your last para. The responsivness of the car should remain the same regardless of your SOC, also it will not hurt your pocketbook or the engine to do a forcecharge and bring the HV to solid green, this only takes about a minute. Try a reboot, it cost nothing and sometimes helps. A ECU or two may be a bit sluggish. :cheer2:
  12. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Personally, I disagree, but everyone is welcome to their own opinion. Even if you are basing that statement solely on the MPG (there are many other reasons for owning a Prius), I suspect the MPG would be quite a bit lower in most other vehicles after your wife drives them for a few days in city stop & go.
    I am curious. What other vehicles would you recommend for someone who drives mainly in the city stop & go traffic? While I personally wouldn't say that the Prius is a bad choice, I certainly wouldn't be so presumptuous as to say that it is the only choice or the best choice.
  13. Patrick Wong
    18,200
    6,493
    No. Don't count on that device or any inexpensive OBD-II reader to retrieve DTC from ECUs other than the engine ECU.
  14. andyprius
    2,212
    188
    I would agree totally with what you are saying. There is stop and go and there is stop and go. The NYC N-S streets ( Manhatten ) used to be one way, either N or S. The traffic lights are timed progressively, so if you maintain the prescribed speed limit you may be fortunate enough to match the lights exactly and maintain a steady 30-35mph. However if you follow the NYC Taxi drivers procedure, then you rush up to every light as fast as possible so you can be the first car at the intersection and then...sit and wait. One method = fairly high mpg. Much of the time it is not the car but, the driver.:cheer2:
  15. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi andyprius. When the SOC is high then the car is much more willing to let the electric motors provide power to boost your acceleration and when the SOC is low then its very reluctant to do so. I definitely notice a difference in the responsiveness to brisk acceleration when the SOC is up around 6 or 7 bars compared to when it's really low like around 2 bars.
  16. andyprius
    2,212
    188
    That could be, I have just not noticed a difference, the car always seems to have good power. My problem is being tempted to use it too much. But the OPs(Bowmanm) problem was not being able to put the charge into solid green. Well if you drive in the flats you may not be able to, unless you force/charge the HV, looks like the OP quit the discussion.
    :cheer2:
