traction slip warning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by olddogrib, Apr 14, 2015.
  1. olddogrib
    olddogrib Junior Member
    North Carolina
    I have a 2007 with 95K, never had brake pads...at 90K they said it was fine. Lately on wet road when I brake it will momentarily flash the dashboard traction warning. Is this a sign I'm finally needing a brake job or maybe a suspension shock strut/issue. It's usually accompanied by a very brief feel of acceleration, but more like a "slippage" in the engine braking than true tire slippage. thanks!
    51,140
    how are your tyres?
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    tires. I have the suck integritys and they slip all the time. if I wasn't such a cheap sob I'd have replaced them when I bought the car. buy some Michelin 205/60r15's and your problem will be solved.
  4. olddogrib
    North Carolina
    Tires are a couple tears old but fine, that's why I don't think it's actually skidding.
  5. bisco
    51,140
    any particular speed when it happens?
  6. Patrick Wong
    18,200
    6,492
    What is the brand/model of the tires, and what is the tire tread depth?
    What tire inflation pressure do you use?
  7. Mendel Leisk
    40,574
    I had traction control kicking in like crazy on a Civic with rear drums. The dealership had just bled the brakes, and handed it back with one of the rear drum brakes completely gone, no braking action. Do you feel any side-to-side rocking as you come to a stop, and find you're overshooting where you intended to stop, say the broad white line at a stop?
    Just a thought. ;)
  8. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I agree with tires. It also happens when braking while going over bumps. It's the result of the ABS system detecting a tiny bit of front tire slip or hop, kicking out the regenerative braking and activating the wheel brakes, with anti-lock modulation as needed. There's a very slight delay between the two that can be perceived as momentary acceleration. The initial tire slip is often too little for human detection. Tires with better wet-surface adhesion will almost certainly reduce the ABS activation. Or, brake more lightly to prevent the system from activating.
    #8 tanglefoot, Apr 16, 2015
