trailer wiring harness info for 2007 Pri
Discussion in 'Gen 2 Prius Main Forum' started by priussoris, Apr 23, 2007.
  1. priussoris
    priussoris New Member
    1,005
    will a converter be needed to wire a small utility trailer that has front and rear side marking lights and rear tail light and lic. light? such as a modulite 18187
    or will the draw-tite 18308 with the wires re-pinned work and power all the lights on a trailer? with out anything else needed?
    thanks in advance
    craig
  2. bobc
    bobc New Member
    361
    Durham, NH
    Can't answer all your questions but with the 118308, you just don't want to be running a whole lot of lights since all the power is coming from car wiring that was just supposed to be powering the rear tailights. From the brochure that came with the 119308:
    "Maximum stop light/turning signal per side is 1 (2.1 amps)
    Maximum number of tailights (4.2 amps)"
    Hope this helps...
    Cheers,
  3. BBKRISH
    BBKRISH New Member
    The standard converter offered is normally a 5 amp per circuit box. At 1/2 amp per buld plus 1 or 2 for bad contacts and high resistence.. you still should be okay with normal trailering
    You can however, go along with a heavy duty modulite that carries up to 20amp per circuit load.
    Those Modulites take the trailer lamp power generation from the 12 volt battery circuits and transfer direct power to the trailer circuit lamp.
    We have installed a few of the simpe converters, but all the modulite converters that are recommended now for any vehicle bypasses the vehicle standard harness circuit power, and uses a detect diode to switch to supplemental battery power.
    No harm to the vehicle electrical system, and all the power you need, based on the sizew of your modulite...
    Good luck with it. Splicing into the vehicle harness does not pose a problem.. the modulite has its own fuseable circuit..
    Bob
    hitch guys in Beaverton
  4. priussoris
    1,005
    Thanks Guys good to know
  5. daniel
    14,487
    1,518
    Spokane, WA
    I don't know about the 2007, but the manual for my 2004 says never tow a trailer. Maybe you'd get away with towing something really light, but the Prius was not designed for towing. So be very careful with anything of significant weight. Note that it's probably the PSD you'd have to worry about, rather than lack of total HP.
  6. priussoris
    1,005
    <div class='quotetop'>QUOTE(daniel @ Apr 30 2007, 07:38 AM) [snapback]432493[/snapback]</div>
    This is for a bicycle trailer only, very light weight if the wife can pick it up I know it's light. And she is recovering from cancer even .
    I dont think the light will be used since we only ride bikes in daytime.
  7. darelldd
    6,057
    389
    Northern CA
    Nothing special will be needed if you use LED lights on the trailer! Your current situation can probably handle a small incandescent load, but I'm not going to add that much load simply because I'll switch everything out to much lower-draw LEDs on the trailer.
    Even if you tow in the day, you'll need brakes and turn signals.
    What trailer are you getting? I ordered SportsRig that is due any day now.
  8. priussoris
    1,005
    <div class='quotetop'>QUOTE(darelldd @ Apr 30 2007, 08:24 AM) [snapback]432512[/snapback]</div>
    Looked into the sportsrig but $$$$ way too much bucks we were quoted 1200.00 plus shipping
    no way. Just going to make a homade trailer frame possibly aluminum or 3/16 steel would like the aluminum though. , flatbed no sides use eye bolts to tie down bikes like you would with a motorcycle. bed to be 1/2" plywood. plus room to carry a cooler or haul other light weight items such as rubber raft or tubes.
    now I have a reg set of trailer lights not LED is there something needed to swap out the incandescent bulbs?
    BTW I got the Curt hitch today what a strong hitch it will never bend like the coastals have that I've seen here. their new number is 11468
  9. RMLamp
    RMLamp New Member
    You may want to check your state laws. In some states trailer lights aren't required if the tow vehicle tail lights remain visible.
  10. priussoris
    1,005
    <div class='quotetop'>QUOTE(8x8 @ Apr 30 2007, 12:29 PM) [snapback]432658[/snapback]</div>
    8x8 your avatar looks like my dog licking the prius windows hahaha we have to clean the glass every day damn dog.
    I think you are right about the state laws I remember seeing that somewhere, thanks I will look it up
  11. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(priussoris @ Apr 30 2007, 09:41 AM) [snapback]432584[/snapback]</div>
    Yup, not cheap. I built my own the first time around, and am convinced that the super-expensive one will be better for me. I hope. ;)
    Your best bet by far is to simply by production LED units instead of replacing bulbs.
  12. Chris_Kewl
    Chris_Kewl New Member
    Kent, OH
    I am looking to hook up a UHaul trailer in January, was wondering if anyone could help me with what I need to do to wire a harness. Is it a standardized method, if so, can someone link me to a place where I can do this?
    I want to hook this up before it starts snowing and install the Curt hitch as well. BTW, anyone know where I can find a cheap Curt hitch for my '07?
    Thanks,
    Chris
    EDIT: Found it: http://evnut.com/prius_trailer_wiring.htm
  13. comatoes
    comatoes #GreenLife
    288
    17
    I'm interested in this as well BUMPPPPPPP!!!!!
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Just installed this on my 07 prius hitch. Works great just plug and play. Has additional power supplies for extra incandescent lighting for any trailer. Plugs right into existing Gen II rear lights. Attach the power lead to battery and ground, run the hitch cable out the bottom drian plug and good to go.
    And my 07 pulls a U_Haul 4 x 7 around town no problem. Thats a heavy trailer.
    It would pull a utility trailer effortlessy. If your doing any towing just change the transaxle fluid every 20,000 miles. Which is cheap & easy. Good Luck!
    Reese 4 way Trailer Hitch Wiring Light Kit plug & Play | eBay
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i recommend public storage. they tend to sell these things cheap. i have an 8 pin (good to have options) that didn't require any rewiring. it works well with my trailer, my hitch light, and any other trailer i've tried. it's powered off the 12v battery. it only cost me less than $40
  16. wiretwister
    wiretwister New Member
    Can I run two small brake light incandescent bulbs on the LED stop light circuit in my 06 Prius? Thanks wiretwister
