Trailer Wiring Problem
Discussion in 'Gen 2 Prius Audio and Electronics' started by brighamwj, Oct 26, 2007.
  1. brighamwj
    brighamwj Member
    120
    Costa Mesa, CA
    There has been plenty of information about the Draw-Tite harness solution for wiring a Prius to a trailer on DarrellDD's super EV site and in naterprius' thread. However, I have a major conundrum and being an electrical rube I will be grateful for any informative comments and advice.
    I installed my re-pinned Draw-Tite 18308 Camry harness two months ago to trailer a Rack and Roll trailer with two 16 foot kayaks.
    For about twenty trips in two months the wiring worked like a charm ...until yesterday. I blew a 10 amp hazard fuse (below hood) and a 7.5 am stop fuse below the dash in smoke ladden Rancho Cucamonga.
    The good folks at Crown Toyota in Ontario were none to pleased to see the Prius towed in with a trailer attached (get the AAA RV trailer insurance). The fuses were $1.16 at Crown, but South Coast Toyota in Costa Mesa tried to charge me $2.54 for the same fuses. Odd, I can't imagine their costs are any different...must be market pricing (gouging).
    I dragged the trailer down to a friends house and checked all the wiring in the harness and the trailer for shorts. We found none, but did find the sealed unit right rear running light had burned out. It is still underwarranty. The trailer is two months old.
    My question is this: Could the burnt bulb have caused the re-pinned Camry harness module to pop the fuses? Can I pop in a new sealed unit and see if it solves the problem or is that ridiculous and bound to burn the bulb? Is the more likely problem that the sealed module in the Draw-tite harness is fried?
    Jason at the local U-haul said that these modules fail all the time and sometimes burn. Has anyone experienced a toasted 18308 module? He suggested that I raise the fuse amperage.
    Another friend who is a lead EE at Intel thought that doubling the fuse capacity to 15 A and 20 A respectively would not hurt a thing.
    Larry from South Coast Trailer and myself are not as sanguine. I have not intention of blowing lights, modules, 26 computers and any chance of warranty service in one fell swoop. I was pleased with my wiring based on DarrellDD's very helpful website, but have come to the end of my deductive rope as to solving this problem. :(
    I cannot hook up the trailer without blowing fuses. If the module is the problem then the harness needs to be replaced. I was hoping on the long shot - that the module is blowing the fuses because of the burnt bulb. A friend of mine who has rewired many trailers and used to sell modules, modulators and harnesses at a part supply shop thought that was most likely the problem; but that solution seems far too easy.
    I would love to get back on the road dragging my kayaks while enjoying the economy and ingenuity of the Prius. Any troubleshooting suggestions or solutions are most appreciated.
  2. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(brighamwj @ Oct 26 2007, 06:47 PM) [snapback]530970[/snapback]</div>
    Ah... bummer! I can't help but think that if the module were at fault that it would blow the fuses even with no load on it. But apparetly you can drive around fine without the trailer lights. That definitely makes me suspect *something* from the trailer. And since you've checked everything for shorts, and found just one problem in the burned bulb, I'd be even MORE suspect that the burned bulb unit is your problem.
    If the failed bulb welded itself short, I suppose that could cause your problem. The module doesn't do much magic. Just combines the turn and brake signals since trailers typically only have one light for both signals - unlike most modern cars. Any problem you have at the trailer is just passed directly to the fuse box in the car. The first thing I'd try is lopping off the failed light, and try again. Definitely worth a couple of bucks (for the fuse) to determine if that's the problem.
    First thing I did with my new trailer is to swap out all the incandescents with LED so there wouldn't be much extra load on the electrical system. I'm not sure what all is involved in this sealed unit you speak of - but if it failed this early, it can't be of very high quality!
    Good luck. Let us know how it goes.
  3. brighamwj
    brighamwj Member
    120
    Costa Mesa, CA
    <div class='quotetop'>QUOTE(darelldd @ Oct 27 2007, 12:21 AM) [snapback]531032[/snapback]</div>
    Thank you for the response. I will let you know how this turns out. Whether or not the culprit is a fried Draw-tite module or a short in the sealed bulb unit is yet to be pinpointed.
  4. darelldd
    6,059
    389
    Northern CA
    For new LED lights, the best advice I can give you is to just Google LED Trailer lights.
    Look through and find what you need. I replaced all of the lights on my tailer, and had to custom-fit them (none were exact replacements). What came on this expensive trailer were about the cheapest, ugliest incandescent lights you can buy. :(
  5. n8kwx
    n8kwx Member
    236
    Arlington Heights, IL - NW Chicago Suburb
    Does your Draw-Tite "module" have a separate 12volt connection to the battery? (Darell's EV site didn't show any indication of that.)
    If your module is not isolated (no separate 12v power), the trailer lights are powered by the Prius lighting circuits. Since incandescent bulbs draw a LOT of power, you likely overloaded the Prius harness. Fortunately the fuses blowing should have protected anything from damage.
    Draw-Tite sells an "isolated" module (the ModuLite). This module connects to your vehicles light harness to sense voltages, but it does not draw any current from the lighting harness. The trailer lights are powered directly from the battery. This fully protects the car from any shorts or overloads.
    For my Camry Hybrid I used the Modulite. My 2nd time out towing one of my trailer lights stopped working. I checked voltages and the module wasn't putting out power. Hmm...
    I found that trailer plug harness had gotten crushed by the trunk latch and some wires were shorted.
    But the Camry lights still worked and I didn't blow any fuses - The isolation works!
    To reset the Modulite, pull its fuse and then replace it. When it loses power the units resets.
  6. brighamwj
    brighamwj Member
    120
    Costa Mesa, CA
    <div class='quotetop'>QUOTE(n8kwx @ Oct 27 2007, 09:21 PM) [snapback]531373[/snapback]</div>
    Thank you for the excellent detailed information. A friend who used to sell modules suggested I check to see if a modulite would work.
    The trailer is powered by the Prius' circuits with no seperate harness connection to the battery through an isolated fuse. Larry at Orange county trailer supply suggested a generic splice in module, but I do not see how that would be any better than the re-pinned module currently in the car.. I wonder if the 01-06 Camry modulite (if available) could be re-pinned in the same manner as the 18308? Does anyone have any experience using a modulite on a Prius?
    A seperate fuse(s) for the trailer lights would prevent the dead on the road experience.
    Also, has anyone heard of a harness produced (or soon to be) specific to the Gen 2 Prius?
    Thanks for the great info.
    :unsure: :unsure:
    I am still shorting with the trailer, even though I removed the fried incandescent.
    I hit a bump with the trailer and when I got home and restarted the Prius (with the trailer removed) I had blown another 7.5 amp. I can't imagine that I caused another short in those sealed lights. Trailers are designed to take a bit of bouncing. I am scratching my head as to what to do.
    I trailered Saturday and Sunday with no incident (sans the bad lamp). Then one bump on the fourth trip and I have blown a fuse again evidenced on the next start (non-start).
    I will take Darell's advice and try some LED's maybe from this merchant http://www.gpartsinc.com/gr-g4002-3.html called Global Parts. They seem to have good prices on standard Grommet mount 2 pin 2" and 3 pin 4" plus beehive and license plate LEDs.
    If that doesn't solve my fuse blowing problem I will look into the modulite (seperate fuses) for the trailer harness. I hope to all hope that I haven't missed an obvious short, and I don't understand how a short could be tempermental and short out several times then not 3 times only to short out again. It only makes sense if the lights have an internal short (again). Even if they are low quality parts. How could they be that bad. Would a circuit begin to short after twenty plus trips if the 7.5 amp circuit is unable to carry the 7 trailer lights?
    Ebay had many grommet mount LEDs with grommets and pigtails if anyone is interested.
    I hope to figure this out yet. Thank you for taking the time to post the helpful information.
  7. n8kwx
    n8kwx Member
    236
    You can wire the modulite easily. Simply cut the wires to the "module" that you already have. Cut them close to the module so you have plenty of wire to work with.
    The Modulite uses the same color wires. L turn (yellow), R turn (green), brake (red), tail (brown) and ground (white?). The generic Modulite kit is fine. You already have the adapters to the Prius wiring harness installed.
    The Modulite needs a 12 volt supply. I wired mine directly to the battery.
    Again, you may not actually have a short in the trailer. If I remember correctly, a brake bulb can draw over 5 amps (one bulb). This alone could be blowing the fuses. The Modulte will safely draw this power directly from the battery.
    Get those Kayaks wet! I have a small (17') Sailboat. Unfortunately Winter is approaching quickly here in Chicagoland. :(
  8. brighamwj
    brighamwj Member
    120
    Costa Mesa, CA
    <div class='quotetop'>QUOTE(n8kwx @ Oct 29 2007, 04:13 AM) [snapback]531866[/snapback]</div>
    Thank you for the generous input. I have replaced the Stop/Turn/Tail, Side Marker, Beehive Clearance Marker and License Plate Lamp with LEDs from Ryderfleetproducts.com.
    I noticed last week that the sealed incandescent tag light was full of water? I figure (duh) here is the problem. Yet, even while drawing one tenth the amperage without the wet lamp or burnt out tail I am still blowing my 10 amp Hazard and the 7.5 amp stop fuses. This is getting very frustrating. I will try to find a short one more time in the trailer wiring.
    If that falls short (yikes) I will go with your suggestion for the modulate in place of the module. There is a nice warranty on that Draw-Tite module (but I am sure I voided it when I re-pinned it per Darrell's website).
    Are there fuses to install in line or installed in the modulite? Are there any negatives involved (such as a slow draw on the battery when not trailering) with wiring the modulite directly to the battery? Are there any special tricks to wiring the modulite to the battery. Is the power wiring included and are there instructions?
    When is draw-tite or some other manufacturer going to produce a harness for the Prii? That is the end of the question barrage.
    Thank you for the help and any information. I will post pics when I get this thing figured out. Has anyone else had similar problems with trailer wiring?
  9. brighamwj
    brighamwj Member
    120
    Costa Mesa, CA
  10. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    I took a different approach to the trailer wiring. I actually use this with my avalon, but could have just as easily used it with my prius. or any other car. I use this for the occasional times that I pull a small trailer to the place at the lake with a riding lawn mower as the cargo. I did not want to tap into the car's system at all.
    The first thing that I did was to isolate all the lights on the trailer above "ground". They get their ground through one of the four pins in the trailer connector anyway. Then I built the somewhat low tech setup shown in the pictures below from things that I had on hand. The only thing that I bought was the tool box. The yellow box at the end of the red cable goes up by the driver. The toggle switch turns on the tail and running lights. The two push button switches are the left and right brake/turn lights. Push them both and the brake lights are on. Push either one of them intermentely and the turn light flashes on the side relative to the switch you are pushing. The 12 volt battery in the center happens to be the same one that I carry in the prius for a jump start if it is ever needed.
    With a little more work, one could add a flasher to make the turn lights work automatically. The heavier current is handled by the three relays on the right side of the box. This setup is also very useful when working on the trailer lights. You don't have to have the trailer connected to the car and you can take the control box with you to the area in which you are working. When not is use, the control box and cables store inside of the tool box.
    Just another way to get the job done.
    Cd=.25 likes this.
  11. brighamwj
    brighamwj Member
    120
    Costa Mesa, CA
    <div class='quotetop'>QUOTE(okiebutnotfrommuskogee @ Nov 12 2007, 12:05 PM) [snapback]538404[/snapback]</div>
    That is a cool gadget. I went to a shop with a tester and the car module is fine. I also pulled a 400 pound flatbead with 11 incandescents on it. Didn't blow the fuses until I plugged in my trailer. When I get it all worked out I will post pictures.
    I dig that Pelican box switch. Really slick, but I am wondering how long will that 12 volt run incandescents? Would it handle 8 hours or 12 hours without a charge? If I was going up from Southern California to Utah or Oregon. It might work with the LEDs I now have on the trailer per Darrell DD's suggestion.
    I am pretty much committed to making it work with the module if I can find the short in the new trailer's wiring. After three controlled tests today I am 99.9% sure that the problem is the darned trailer.
    Thank you for the input I am sure others will get some good ideas from your self contained trailer power and signal unit. It is a bit beyond my electrical competency to think through something like that without a lot of help.
  12. okiebutnotfrommuskogee
    1,813
    Tulsa, OK
    <div class='quotetop'>QUOTE(brighamwj @ Nov 12 2007, 10:45 PM) [snapback]538694[/snapback]</div>
    The battery is only 12 amp hour rated, so it wouldn't last very long with night time driving using incandescent bulbs, but it might do well with LEDs. I only plan on using it during the day and the trip is only about an hour each way.
    I hated to drill holes in the Pelican box, but I had it and it fit the need.
  13. n8kwx
    n8kwx Member
    236
    <div class='quotetop'>QUOTE(brighamwj @ Nov 11 2007, 08:50 PM) [snapback]538167[/snapback]</div>
    I'd suggest going with the Modulite no matter what. It will protect your electrical system.
    I bought the #118176 Modulite. This one is "universal". As I described in my previous post the Modulite will wire into the wires from your existing "Camry" kit. Cut off that old module and wire in the Modulite.
    For the 12volt supply, I bought an inline fuse holder from Radio Shack. I think I used a 10 amp fuse. No problems with running the battery down. If they designed the Modulite well, it should have very little parasitic current draw.
  14. flocculus
    flocculus New Member
    Hello all
    I'm having a bit of a different problem and wondering whether anyone has ideas.
    I used the same Draw-Tite 18308 wiring setup (Thanks, Darell and Nate!). So far, I haven't plugged any trailer wiring into it. However, since installing it, I'm getting occasional electrical problems with the Prius. The Brake and ABS warning lights come on at times, then go away when the car is restarted. And, a couple of times, it has been hard to get the car started. It will respond to the Start button with various lights but not "Ready". After 6 or so restarts/reboots, it eventually works. I've now removed the wiring to see if this goes away, but not sure yet.
    Has anyone seen similar behavior? Is it likely related to the wiring? Would changing to the Modulite make a difference? Doesn't seem so, since there is no load on this wiring yet.
  15. whburling
    whburling Junior Member
    53
    17
    Gales Ferry, Ct
    It is my belief that changing over to a Modulite or even purchasing LEDs will not fix the problem. I support both recomendations but only because I value the of LEDs and circuit isolation.
    I believe the problem is in the harness with a remote chance it is
    in the bulb receiver. If the problem is in the harness then LEDs and Modulite will not fix the problem (Actually the Modulite will fix the
    car fuse problem, but will cause the Modulite fuse to fail thus displacing the problem, not fixing it). So Here is my thinking:
    If I summarize your observations correctly, you are saying that when you drove over a bump, you discovered that a car fuse was
    blown when you finally arrived at home.
    I interpret this problem to be an intermittent short revealed through the bumps. If you were driving during the day when you encountered that bump, that suggests the short is in either the turn signal circuit or in the stop signal circuit. If you were driving at night you would also have to include the running light circuit.
    Finding an intermittent short is not easy. I would trace the intermitent short with the following proceedure. Begin by looking at the trailer. Do the wires run in conduit or do they run, exposed, through occasional eyelets?
    If they do NOT run through conduit, I would first check the wires for
    exposure (bare) as they run through the eyelets.
    In addition, you might remove all bulbs from the trailer, connect the drawtite to the trailer harness and run car and trailer over bumpy
    roads. try running with just the left blinker on........then after about
    10 bumps, try running with just the right blinker on......if after each test you still have not blown a fuse.......go over the bumps hitting the brake at the same time. check the fuse after each run. Finally try running lights in the same manner.
    If the above does not blow a fuse, then the odds are that one of the bulb receivers is not functioning correctly. Insert only one bulb and run the tests. remove and insert a different bulb and run the tests. repeat until all bulbs have been tried (separately). between each bulb changout, check the fuse.
    l hope this helps. Please let me know how your experiments ended or what you may have done that enabled you to diagnose the problem successfully.
    Bil
