Transaxle fluid change last night
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nemebean, Sep 1, 2021.
  1. nemebean
    nemebean Junior Member
    42
    28
    Just changed the fluid in the transaxle on a new-to-me 2007 with 125k. Thought I'd write down my observations for posterity:
    • Driving the car up on a couple of 10 foot 2x6s gave me enough room to work and kept the car level through the whole process.
    • A surprising amount of fluid came out when I removed the fill plug. Luckily the floor where I was doing this is already a disaster so no harm done. ;)
    • An 18 inch breaker bar made removal of the drain plug soooo much easier. I spent way too much time messing around with a regular 3/8 ratchet.
    • Once you get the drain plug out, the fluid comes out fast! It almost filled up the funnel area on my container. Now I understand why it has a vent cap you can open.
    • 5/8 OD-1/2 ID clear tubing was perfect for this job. My funnel fit into it nicely, and the tubing fit tightly into the fill port so I didn't have to worry about it falling out.
    • The drain plug was pretty fuzzy, but no big chunks. The fluid still had some color to it so overall I feel pretty good about the health of the transmission. I suppose it's possible it had already been changed, but after seeing the condition of the cabin air filter I'm doubtful the previous owner would have done that.
    • ATF at my local dealer was comparably priced to Amazon, but they charged something like $3.29 apiece for the washers.:confused:
    • It feels really good to have done this and hopefully extended the life of a very expensive component. :D
    OC63RAG, Mendel Leisk and ydpplqbd like this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Where is the vent cap you can open?
  3. Mendel Leisk
    38,705
    If you could find it, wouldn't opening a vent cap make the fluid come out even faster??
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,218
    5,902
    Columbia, SC
    Considering it is very wise to crack open the fill port before draining the transaxle, there shouldn't be much need for a 'vent cap'.
    Sure would suck to drain that puppy and then find out you can't remove the fill plug.
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I think he was talking about the vent cap on the drain pan.
  6. TMR-JWAP
    6,218
    5,902
    Columbia, SC
    Now that you mention that, it makes much more sense. All the oil catch containers I've used have the tops that are sloped toward the center with about a 3/4" hole in the center (with a thread in plug). Off to the side is a 1/4" diameter vent with a cap that just pops on or off depending on whether you're draining into it or transporting it.
    2010moneypit? likes this.
  7. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
  8. nemebean
    42
    28
    Yep, exactly. There's a little plug you can open on the top of my catch container that would allow air to vent as the fluid fills it. With that closed, the air was trying to get out the same opening the ATF was trying to get in and it didn't work well.
  9. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Great to hear! While not critical, it's a good idea to torque the plugs to 29-37 ft/lbs unless you are experienced with snugging them up.
    AND you saved yourself a TON of money by doing it yourself! I was at my dealership picking up some oil filters and asked the service guy what they charge to drain/fill the CVT in a Prius....$320.....dang!!
    Next time, just order the plug crush washers on Amazon...90430-A003 or the newer is 90430-18008....I keep a stash as that's pretty standard in Toyota's. (We have 5 in my family)
  10. Mendel Leisk
    38,705
    It may be 29 ft/lbs for both. 29 is spec'd for the fill bolt, but I didn't see anything for the drain plug (hey it's lifetime fluid...). For 3rd gen both bolts are 29, fwiw. 2nd gen transaxle fluid check (Repair Manual excerpt) attached:
  11. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Good catch, Mendel, I forgot he was servicing a 2007!!
  12. Mendel Leisk
    38,705
    Too, 2nd gen has different bolts for fill and drain. Again, I couldn't see a torque spec for the drain bolt, though I didn't look that hard. A little frustrating if they're omitting it. 29 (or heck, 30) for both couldn't hurt.
  13. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    When I got my transaxle fluid changed in 2012 at autobeyours Prius salvage place in Indiana they filled from the side by removing a 10mm bolt. I changed mine yesterday and loosened the three 10mm bolts on the side, the one on the right was the first one I opened and there was a pressure release sound. But.. when I tried to place a tube in all three, the holes had a back and tube didn’t go all the way in. I didn’t try the 10mm next to the electrical connection. I wish I would have taken a photo of which bolt they filled through on the side.
    has anyone tried filling that way ?
  14. Mendel Leisk
    38,705
    This is from the 2nd gen Repair Manual, shows the fill and drain bolts:
    You should fill through the "filler" hole, with the car level, till it starts coming back out. You used Toyota ATF WS?
    Pdf attached:
  15. edthefox5
    10,096
    4,805
    Clearwater, Florida
    What 10 mm bolts on the side? Like Mendel shows only has a fill bolt and a hex dump bolt in the bottom.
  16. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Never seen a catch can with a vent and a cap. Why lol?
    Sounds like it would make a holy messy as it did with you Just use the super wide oil change bucket they sell at parts stores. Then you just pour it into a Plastic container with A cap on it. No mess.
  17. edthefox5
    10,096
    4,805
    Clearwater, Florida
    No.
  18. nemebean
    42
    28
    It's both the catch and storage containers in one. There's a wide funnel on top that you use to catch the oil, and it goes directly from there into the storage container. For regular oil changes it works quite nicely because the oil doesn't come out so fast. It worked for the ATF too, but I had a few nervous moments as it nearly overflowed the funnel part. Cracking the vent would have avoided even that.
    Most of the fluid I spilled was because I didn't have the container in place yet when I opened the fill port. I wasn't expecting much, if any, fluid to come out when I did that, but I got a nice little puddle before I could get the funnel under it.
  19. Mendel Leisk
    38,705
    Was the car level when you removed the fill bolt?
  20. nemebean
    42
    28
    Pretty close. The garage floor where I was doing this is old and not perfectly level, but according to the bubble level on my phone it's within a degree or two. All four tires were up on 2x6's to give me room to work, so it should have been basically level.
