Transaxle oil gen3
Discussion in 'Gen 3 Prius Technical Discussion' started by Profanas, Jun 7, 2020.
  1. Profanas
    Profanas Junior Member
    35
    Lithuania
    2013 Prius+ MPV
    Hi
    I have prius (plus+ in eu, or V in usa), but still.. engine and transaxle ar same like 3gen..
    Engine have more like 500.000km (300.000miles), transaxle have original oil and i wanna change that. In my country Toyota atf ws price is not so cheap.. i thinking about Dexron VI, dexron have "ws" to.., can i use it?
    Thanks!
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,535
    2,570
    Taylors, SC
    No, you should use Toyota WS. Others are incompatible with the electric motors and might not have the correct dielectric qualities.
  3. Mendel Leisk
    42,079
    It's available though? How much is it?
  4. ASRDogman
    ASRDogman Senior Member
    7,919
    4,024
    How often are you planing on changing it? You said you have gone 300,000 miles without changing it.
    It should be worth it to use the correct fluid and go another 300,000 miles?
  5. Profanas
    35
    Lithuania
    2013 Prius+ MPV
    Maybe every 100-150k miles, but not every 30-40k like another people do, then better oem toyota atf ws? Dexron vi not so long life?
  6. Profanas
    35
    Lithuania
    2013 Prius+ MPV
    About 14-16euros for 1liter, dexron 6 about 5-6euros
  7. Mendel Leisk
    42,079
    Yeah my price was $9.14 CDN per litre for Toyota ATF WS, last change, maybe 3 years ago. Current exchange rate that would be 6 euros, same as regular fluid for you.
    Considering it's just the once, and what's at stake, I would stick with Toyota. Frustrating though.
    Or at least a very close alternative, if someone knows.
    ASRDogman likes this.
  8. Profanas
    35
    Lithuania
    2013 Prius+ MPV
    How much i need? somethink about 3.2liter?
  9. ASRDogman
    7,919
    4,024
    I know others have used different brands other than Toyota. And claim no problems.
    That doesn't mean there aren't any, yet. Maybe you can use something else. But for me,
    The cost of the transmission is not worth the risk. In Florida, the cost difference is only
    $1-2, so I use the Toyota fluid.
    Since you are going to change it at 100,000 miles, how many months, or years will that be?
    So spending the extra money for the correct fluid over time is not that much. Plus the peace
    of mind knowing you did the job correctly.
    Have you tried looking on Ebay for it?
    Ed Beaty and Georgina Rudkus like this.
  10. Mendel Leisk
    42,079
    Get 4. Somewhere between 3.5 and 4.0, filling with the car raised and level, it'll start overflowing. That's correct level.
    29 ft/lbs torque for both bolts.
    Aaron Vitolins likes this.
