Transaxle oil, recent analysis
Discussion in 'Gen 2 Prius Technical Discussion' started by bwilson4web, Sep 6, 2010.
  1. bwilson4web
    16,501
    BACKGROUND
    Jeffrey began changing his transaxle oil every 60,000 miles which now includes 120,000 and 180,000 miles. His is a 2004 Prius and now we have a clean record of Type WS history in the NHW20. I've just uploaded Jeffrey Denenberg's latest transaxle oil testing results to the Yahoogroup SAT2 files along with a spreadsheet with the data.
    REPORT
    (1) additives - after the first change, no effect. There isn't much we can do about them since they are mixed when the oil is formulated. There is evidence the first 60k change saw some usage but since then, nothing.
    (2) wear materials - great profiles, we know Si decreases due to the sealant leaching finally being covered by less soluble material. The Fe decrease is likely, partially due to the sealant pigment, iron oxide, as well as gear surface polish. Speculation but a sealant with another pigment material might let the us track gear wear more accurately. Al, Cu, and Zn appear to be accurate wear materials for what is going on inside the transaxle. Everything else appears to be trace material likely left over from assembly and manufacture.
    (3) viscosity - great profiles although the 100C rate of 'shear down' seems to trend downward. Still it met the 15% threshold.
    (4) trace - the Na and Mg are worth watching but these are at the limits of detection. The concern is these may be the harbinger of some 'leakage' into the transaxle but at such low values as to be at the limits of detection. The concern is any coolant leaks into the transaxle would also increase or add water, a bad thing.
    CONCLUSION
    Based upon the Al, Cu, and Zn levels, increasing the oil change interval above 60,000 miles looks feasible. This is offset by the loss in 100C viscosity that has reached the 15% threshold. Extending the next oil change to 90,000 miles makes sense with testing to see what Al, Cu, Zn, and 100C viscosity levels go to. Adjusting change intervals to achieve level Al, Cu, and Zn makes a lot of sense.
    Jeffrey reports,". . . the first interval should be at 30k followed by 60k (perhaps) then stretching it out . . . " which agrees somewhat with my plan for my wife's 2010 Prius, ZVW30.
    I did the first transaxle oil change at 5k miles with an extended analysis. In addition to flushing the manufacturing and initial wear material this change showed a straight-line to a 15% viscosity loss at 15k miles. So now I'm waiting until 20k for the next change. I'll adjust the subsequent change intervals based upon the straight-line estimate to a 15% viscosity loss. Eventually we will find a stable distance, the interval that leads to reproducible, 15% viscosity loss.
    Bob Wilson and Jeffrey Denenberg
    SFO and bisco like this.
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
  3. 2009Prius
    2,705
    512
    63
    The 100C numbers are 4.7, 4.9 and 4.7 for the 3 changes respectively. Not sure how that shows any "trend downward". Looks more like measurement noise maybe?
  4. bwilson4web
    16,501
    We're seeing the 100C viscosity hitting on the 15% viscosity limit:
    Column 1 Column 2
    0 40C % 100C %
    1 13.4% 14.5%
    2 9.3% 10.9%
    3 9.8% 14.5%
    Percent loss of viscosity for 40C and 100C measurements.
    In practice, we'd like to see the viscosity loss average above and below the 15% target. Although the 40C viscosity has a lot of head room, the 100C is just at the 15% limit. The hotter temperature approaches the operational transaxle oil temperatures I've measured with my NHW11, 60C, on a hot day at high speed and more likely closer to the gear and bearing temperatures.
    It makes sense to extend the interval and test again, say 90,000 miles. These are small steps reaching out towards what hopefully remains on the conservative side of the wear curve. Sad to say, we are just learning what works in our Prius:
    • NHW11 - a few of us continue to study these older vehicles.
    • NHW20 - the vast majority of today's USA fleet.
    • ZVW30 - the growing fleet, this is my wife's car currently under test.
    We'll let the data tell us what works and doesn't. For example, we already know Amsoil ATF is Type T-IV viscosity compatible but it eats yellow metal. We learned this with my NHW11.
    This effort would move forward a little faster if we had more participants. Folks willing to send their transaxle oil samples off for the $20 testing expense and then sharing the results. Empirical data that can help others extend their vehicle performance and transaxle life.
    SFO and 2009Prius like this.
  5. douglasjre
    douglasjre Senior Member
    2,239
    749
    Null, NL
    what is transaxle oil? How do I change it? Where should I purchase it?
  6. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The lubricant in your transmission which is Toyota type WS and it takes a gallon of ATF to do a drain and refill. Your Toyota dealer should charge about $100 to do the job.
    Think about doing it at 30,000 miles and every 60,000 miles thereafter.
    JeffD
  7. wolfeberg
    wolfeberg Appreciative Member at large
    26
    Chugiak, Alaska
    I just changed my ATF at 74,500 and saved a sample. Would it help with your efforts if I sent it in to be tested.
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Bob is off the forum for some unknown amount of time. Please do get it analyzed and post the results. I'm sure someone will eventually use the data.
    I plan to change mine for the 1st time at 5,000 miles and will add it to the data.
  9. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you post your results on Yahoo's Prius_Technical_Stuff and at MyHybridCar, Bob Wilson (and I are certain to see it and add it to our long term analysis. You should use:
    http://www.randglabs.com/PDF/Oil_Division/Choose.pdf
    To insure consistency with our other ATF tests and include a viscosity index test. It is reasonably priced at about $25.
    JeffD
  10. 2009Prius
    2,705
    512
    63
    And mention "Bob Wilson" to get a special discount at R&G. Good luck! :)
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I neglected to collect a sample this time, sorry folks. I'll get one next exchange at 180k miles. Does it matter what part of the stream is collected ? Towards the end sounds less messy.
    By the way, the WS shot up in price. I paid close to $40 for a gallon.
  12. 2009Prius
    2,705
    512
    63
    I would say near the middle. Definitely not the initial gush or the final drops. I would also clean the area around the outlet before taking off the bolt.
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yup, exactly like collecting a urine sample and for the same reasons. Except for taking out the bolt.
  14. wolfeberg
    26
    Chugiak, Alaska
    Okay thanks for the info. about the R&G Lab. I collected the sample in a clean glass jar. Do I need to send it to them in a glass container or can you use a plasitic one without worrying about contamination? Also, do I have to specify which tests to be done or just mention Bill Wilsons name and they will do a standard set of tests?? I tried to find answers to these questions but couldn't locate it for some reason as I am sure it has been discussed before. I even looked on the Yahoo group page but couldn't see it. Thanks for any link for instructions on having the tests done.
  15. 2009Prius
    2,705
    512
    63
    I believe clean plastic bottle is OK. It's Bob or Robert, not Bill. Standard test plus viscosity index if not already included. Good luck! :)
  16. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Not only is plastic (poly) OK, but in the past R&G labs would send you some bottles and a mailing envelope if you ask.
    JeffD
  17. wolfeberg
    26
    Chugiak, Alaska
    Thanks. I will try to contact the lab to see if they will send me whatever I need to send in a sample.
