Transaxle Plug Identification - which plug is witch?
Discussion in 'Gen 2 Prius Main Forum' started by KiwiAl, Feb 2, 2014.
  1. KiwiAl
    KiwiAl Junior Member
    146
    New Zealand
    Hi Guys,
    This is more for others than for me, because I struggled to find on PC which are the ATF Level/Fill and Drain plugs and which are the Transaxle Coolant plug(s), and it would be nice to have them confirmed for all.
    Referring to the photo below, taken from the front underside of the Transaxle, with the ICE on the left:
    Please correct me if this is incorrect:
    Plug:
    A - Transaxle & Inverter Coolant Drain
    B - Transaxle ATF Level, optional Fill
    C - Transaxle ATF Drain
    Also, spotted another plug on my 2008 Transaxle. Can anyone confirm, this is the intended ATF Fill Hole, pictured below? It's just below the Inverter, the orange wires are the power to the A/C Compressor and the large Power Plug cover is for MG1 - nearest the ICE on the LHS of the photo.
  2. JimboPalmer
    12,470
    6,869
    Greenwood MS USA
    You have it correct.
  3. Patrick Wong
    18,200
    6,479
    I would call that the factory "fill" hole. It is not intended that this would be used for normal maintenance since the inverter has to be removed for access.
