Transaxle Whining
Discussion in 'Gen 2 Prius Main Forum' started by Omerfidakhan, Aug 21, 2019.
  1. Omerfidakhan
    Omerfidakhan Junior Member
    Palistan
    I noticed that car whines at cruising speed. To replicate the sound I jacked-up the front wheels and put the wheels in motion in D. I never noticed this sound in my father's Gen3. Is my transaxle fried ? please help
  2. Omerfidakhan
    Palistan
  3. Omerfidakhan
    Palistan
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    How long have you owned the vehicle?
    How many miles do you have on this gen2?
    Has the transmission fluid ever been changed?
    Have you checked the wheel bearings already?
    In the future, please don't spam the subforums with the same issue or advertise for other threads.
    Raytheeagle and Skibob like this.
  5. Omerfidakhan
    Palistan
    M sorry for spamming our of frustration dear.
    Car is putting on 200k plus kms. I m pretty sure that Transaxle fluid has not been changed. Do you think changing the transaxle fluid would help out or the damage caused is physical?
  6. Omerfidakhan
    Palistan
    Moreover I have checked the wheel bearing, they are ok. I sticked my head into the hud while my brother pressing the accelerator pedal. The sound is clearly coming from trany
  7. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    What device are you using to read the OBD2 codes with, as you may need a hybrid compatible scanner.
    Replacing the transaxle fluid will help it last longer in its current state, doubtful if it would fix a noisy transaxle. It could be worth a shot though, and far less expensive than a having transaxle that gets worse over time and eventually fails completely.
    Skibob and Raytheeagle like this.
