Transfer Case and Fuel induction cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paphillyman, Jun 24, 2019.
  1. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    Got a postcard in the mail today from the Toyota dealer saying I should get Transfer Case Service and Fuel Induction Cleaning done .
    is the transfer case service the CVT transmission oil and If I clean the manifold and the egr would that take care of the fuel Induction Service I also got some BG 44K for the fuel system , which is suppose to clean fuel injectors ,intake valves ,ports and combustion chambers
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    A dealer attempt at drumming up business:cool:.
    How many miles on your Prius? Ever drained and filled the trans fluid?
    I’ve used the 44k from BG Products and I think it helps with the fuel injection side of the equation ;).
    I’d ask for specifics from the dealer before proceeding with them(y).
    49,488
    how much? how many miles?
    i always relate a transfer case to a truck :confused:
    The Critic likes this.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No Prius has a transfer case, it is a part used in 4WD trucks. Transfer case - Wikipedia
    Fuel induction cleaning is very often bad for a Prius, you will see many threads "I decided to clean my throttle body/intake manifold/MAP and now I get codes!" I would never do that unless there were specific codes already.
    What this postcard really means is your dealership wants more of your money and they hope you will give it to them. Never go there again, some other dealer/mechanic in your area HAS to be more honest and informed.
  5. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    ok thanks wasn't sure so I asked , my car only has 49,600 or so , I did change the trans oil like a couple of weeks after I got the car and did most of the diy jobs from NutzAboutBolts videos
  6. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    You’re good for a bit then;).
    Good luck (y).
  7. Mendel Leisk
    38,726
    "Transfer case"? I heard about that with a 4WD Pilot, had to change the fluid....
    They're fishing for business. I got one of those, early into our Prius ownership, they were babbling about propeller shaft or something.
    Montgomery and Raytheeagle like this.
  8. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Was that because they were trying to keep themselves afloat:p?
    Montgomery and Mendel Leisk like this.
  9. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Cant' help it, I laughed out loud reading this. I mean people here get recall notices from toyota and they won't even get it done, free also.
    RMB likes this.
  10. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Me too. Transfer case?
    RMB and Raytheeagle like this.
  11. Mendel Leisk
    38,726
    Still got half the bottle of hypoid gear oil. That stuff's like maple syrup, just as expensive too. :( Don't mix 'em up though...
  12. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    Does someone have a picture of the underside showing the location of the transfer case? LoL
    Montgomery likes this.
  13. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Transfer case is a joke:eek::whistle: LOL but I had experiences with BG Air Induction Service.
    Yes dealer's service department does always try to up-sell extra services at the 30k, 60k major services etc. For the particular dealership I worked at back in the days, service advisors were tagging along 4 wheel alignment and BG air induction cleaning at the "Majors", thus I have done and seen many of these induction system cleanings, including my own old dirty cars.
    I brought my AE86 Corolla into the shop on a Saturday, I ran this service back to back (I didn't pay for them :ROFLMAO:), once completed put a flash light to look, my once filthy throttle body/intake manifold was free of oil, buildups, looked shiny clean as new. I am telling you, it WORKS, BG induction system cleaning does what it advertised to do.
    ~~~ HOWEVER ~~~, I am not saying you should pay the dealership to get this done because they charge an arm and a leg (maybe a kidney?), while @NutzAboutBolts has already taught us to DIY with his own blood and sweats, filmed the process and went through hours of video editing to tell us it can be done at home:love:. I would just pocket the extra spending that otherwise would go to someone else's timeshare payment.:D
  14. Mendel Leisk
    38,726
    I would just lift off the throttle body, clean both sides with a rag with carb cleaner spritzed on it. No need to even disconnect the coolant lines.
    mikey_t likes this.
