Transfer Contact List to Bluetooth
Discussion in 'Gen 4 Prius Main Forum' started by jerryd, Jan 20, 2019.
  1. jerryd
    jerryd Junior Member
    51
    Florida USA
    Gen4 forum,
    Samsung SGH-T404G phone
    I am trying to update my contacts list from my phone to the
    bluetooth on my 2018 Prius III 7in screen. When I originally
    paired the phone to the bluetooth the contacts list transferred
    just fine. Now when I go to Settings > Phone > Transfer Contacts"
    it immediately disconnects my phone and doesn't transfer the list.
    I have tried everything I can think of on the phone but no luck.'
    It's not a cell phone but more like a flip phone.
    Any suggestions?
    Jerryd
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    Your phone needs to be "paired" with the Prius screen. Do you see that your phone is paired if you go to Bluetooth setting on the Prius screen. Also, Bluetooth needs to be enabled on your phone - they can only pair with each other if each side has Bluetooth enabled.
  3. jerryd
    51
    Florida USA
    The phone is paired with the bluetooth because I have been using it for some time.
  4. booke02
    391
    415
    Israel
    Jerry - can you make/receive calls using the Prius screen?
  5. jerryd
    51
    Florida USA
    I do use the Prius Screen to make calls I'm just trying to update the contact
    list from my phone to the bluetooth list.
  6. booke02
    391
    415
    Israel
    Jerry - if you can make calls, then the devices are talking to each other.
    On your phone, go to Settings, then Connected Devices. You should see something like Paired Devices or Previously connected devices - click on the settings icon to the right of Toyota Touch, and verify that Contact Sharing is allowed.
    The Professor likes this.
  7. jerryd
    51
    Florida USA
    booke2,
    Thanks for the replies.
    What is actually happening is my phone connects as soon
    as I start the car and when I can get to the point
    where the Prius screen says transferring contacts my phone
    immediately disconnects from the bluetooth.
    If I go to the bluetooth on my phone and tell it to connect
    it will but then immediately disconnects again.
    I didn't find anything like Connected devices or Contact
    Sharing in my settings? Remember it's not a cell phone.
    Jerryd
  8. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,585
    near Brisbane, Australia
    I'd remove the connection - at both ends - and try again.
    With my last car, the bluetooth connection became eratic, and I was able to "debond" it (I think that was the term FORD used to remove it), and then re-pair-ed it successfully. Long time ago, don't remember details though.
    kithmo likes this.
  9. jerryd
    51
    Florida USA
    alanclarkeau,
    You think I should unpair and start all over even though everything
    else works except updating my contact list?
    Jerryd
  10. alanclarkeau
    7,044
    7,585
    Yes, I'd try that - if all else has failed. That's what I had to do with my FORD - but that was about 4-5 yrs ago, and not a TOYOTA.
    Tyfly likes this.
  11. krmcg
    2,592
    2,390
    Whittier, CA
    What's the harm?
  12. alanclarkeau
    7,044
    7,585
    Probably none. Occasionally mine doesn't pair when I get in - but it comes good when I turn BlueTooth off and on on the phone - or reboot the phone. But if that didn't work, I'd debond them both and start again.
    krmcg likes this.
