Transfer Data from Phone
Discussion in 'Gen 2 Prius Main Forum' started by fulfowi, May 1, 2009.
  1. fulfowi
    fulfowi Junior Member
    Irvine, CA
    I have a 2009 package 6. When I try to transfer data from my phone, it never completes and I get no data. Am I doing something wrong, or is it broken?
    Doug
  2. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    You need to say which phone. Not all phones support transfer of contacts, even though the bluetooth otherwise works. There's a particular bluetooth protocol that has to be supported for transfer of contacts to work.
  3. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Correct. For example, my iPhone 3G will not transfer contacts. Grrrr
  4. Nortnarg
    Nortnarg Prius~To go before
    83
    Blue Springs, Missouri
    Yes, depends on the phone.
    My Sony Ericcson will transfer, but only one contact at a time. Better than not at all.
    You have to set the Prius to accept the transfer, then go to the phone and make it send via Bluetooth.
  5. lmtprius
    lmtprius New Member
    Ohio
    If you do not have a phone that supports the BT push/pull, you can use a laptop with bluetooth. I have a Razr. I imported my phonebook to my PC, created a VCF file. The VCF file is a CSV file with name and numbers. The Prius phonebook only allows 2 numbers per name. Create the name, number1, number2 CSV file, rename the file extension to VCF. I xferred my entire phonebook with 1 operation.
  6. blamy
    blamy Member
    380
    Central Florida
    Motorola's will only transfer one at a time. Can be very time consuming.
  7. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    fulfowi, you'll also get some better information in the Audio and Electronics forum, rather than the Main forum.
    Seems like half the topics there are about phones and BT; the other half are people trying to upgrade the sound system... ;)
  8. alexdayjr
    alexdayjr New Member
    washington DC
    what model cellphone do you have
  9. alexdayjr
    washington DC
    is your cellphone paired to your Prius? if you are unable to transfer, you can input names and numbers manually.
