transfering phone book
Discussion in 'Gen 2 Prius Audio and Electronics' started by Raenstoirm, May 4, 2004.
  1. Raenstoirm
    Raenstoirm New Member
    179
    Maryland
    I have the T616. The phone works fine with the car (I am not too thrilled with cingular but that is not the cars fault). Anyway when I go to transfer the phone book, the phone reports "missing URL". I saved some numbers as "contacts" and some as "sims" thinking it makes a difference. The car wont take either.
    Suggestions?
  2. Sylko
    Sylko New Member
    28
    Switzerland
    I had a problem of synchronization with my T610 with errors all the time. I tested again by removing some numbers in my phone and by keeping only those which I considered important. Finally was ok.
    So, it's perhaps the cause of your problem. You have too much adresses.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Raen,
    Have you looked at the tutorial at http://John1701a.com's web site to make absolutely sure you're doing the process correctly? I've never seen that message when transfering with my [nearly identical] T610 (btw, T-mobile ain't that great either).
    That said, I haven't been able to upload the phone book the last 10 tries or so though I had no trouble at all with the initial uploads
