Transmission clicking noise while parking.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by James Chiu, Jul 8, 2015.
  1. James Chiu
    James Chiu Junior Member
    Taiwan
    I notice this lound noise while I change from P to R/N/D.
    Is this normal?
    49,397
    doesn't sound right. not the door locks?
  3. James Chiu
    Taiwan
    The sound comes from engine for sure.
    49,397
    i wonder if it could be the parking pawl releasing.
  5. Tapio Kuosma
    Tapio Kuosma Junior Member
    Wow, that doesn't sound right at all. Don't know how and where you recorded this, but I've noticed a slight click when changing gears on my 2010 if it's parked next to a wall or another car. That way the sound bounces from that object nearby and I can hear it. But not those amounts, not even close. I would change the fluid first, check the drain plug for metallic "leftovers" and try again.
  6. Z28PRIUS
    Z28PRIUS New Member
    CANOGA PARK
    Its the shift actuator
  7. A617
    A617 Member
    213
    95
    OKC, OK
    Its fine, that sound is from the parking pawl actuator engaging and disengaging when you shift in and out of park.
