Transmission codes
Discussion in 'Gen 2 Prius Main Forum' started by Gr8ful dev, Oct 2, 2022.
  1. Gr8ful dev
    Gr8ful dev New Member
    Missouri
    Sometimes the car drives just fine other times it acts funny hard in the pedals steering wheels to stiff other times is too loose but the main problem is when I'm hitting the gas it's hitting at a high RPM sounds like it's in 5th gear almost and has trouble getting up to speed then it'll be just fine two seconds later also I've been noticing a funny smell of gas or almost like butane smell so I think it might be something to do with the catalytic converter here's the codes
    01-05 190-56- C
    01-DC 190-CA- 5
    01-DC 106-9C-F
  2. ChapmanF
    18,798
    Lots of people discover those self-diagnostic screens in the infotainment system and think they've discovered an easy trick to diagnose car problems, but. sadly, no: the codes you found are only useful for diagnosing the infotainment system itself.
    Diagnostic codes for issues with the car all look like a letter P, C, B, or U, followed by a digit 0, 1, 2, or 3, followed by three more chosen from digits 0–9 or letters A–F, and to read them you need a separate scan tool plugged in at the car's diagnostic port.
    Are any warning lights showing on your dash?
    If you eventually want to follow up those infotainment system codes, you can find troubleshooting info for them in the repair manual. But probably you're more concerned about the possible mechanical issue for now.
    Toyota Service Information and Where To Find It | PriusChat
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    You’ll know it has codes when it gets the red triangle of death and every diagnostic light comes onthe dash.
    Sounds like the hybrid battery is end of life. It provides most of the power.
    All G2 battery’s are either failed or failing it’s just time.
    what’s the battery behavior look like on the mfd?
  4. Gr8ful dev
    Missouri
    It can't be I bought a brand new one last year
  5. dolj
    dolj Senior Member
    8,620
    4,375
    Wellington, New Zealand
    Actually brand new (from a Toyota dealer) or one from a place like Greentec or Greenbean?
    edthefox5 likes this.
  6. Gr8ful dev
    Missouri
    As in directly from Toyota
    dolj likes this.
