Transmission Failure - Help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bernie Garrett, Dec 10, 2008.
  1. Bernie Garrett
    Bernie Garrett New Member
    Vancouver Canada
    2001 Prius
    Hi folks,
    The transmission in my 2001 Prius has just failed (according to our Toyota dealer) and they are quoting me $6K CAD to get it replaced. :eek: It runs but there are 2 error codes indicating a problem. Any suggestions, as this seems a lot to put into a 2001 vehicle and the alternative they are suggesting is scrapping it, or PX on a new model!
    Cheers
    Bernie
    Vancouver, Canada
  2. Patrick Wong
    18,200
    6,471
    Hi Bernie,
    Pls provide the DTC logged so that we can confirm the likelihood that the transaxle is the problem.
    Assuming that the transaxle indeed has failed and you wish to keep the car, one alternative would be for you to obtain a salvage part from a low-mileage accident vehicle hit from behind, and have an independent mechanic install it for you. The labor job is pretty big as the engine/transaxle must be removed from the car as one assembly; then the transaxle must be separated from the engine, the new one mounted to the engine, then the engine/transaxle is reinstalled into the vehicle.
  3. tochatihu
    tochatihu Senior Member
    9,045
    3,528
    Kunming Yunnan China
    2001 Prius
    My least favorite part of PriusChat is to read a first post like this one. Very Sorry Bernie but as Patrick suggests we need to develop a clear view of your options.
    I do not know if there is a Canadian equivalent to the US Toyota Customer Experience Center tel. 800-331-4331. Perhaps we can ask Canadians how they have dealt with post-warranty issues in another thread?
    Because the US fleet of 2001-2003 Prius is much larger, it may be that you'd have the best choice and price for a salvage transaxle from there. I do not know how shipping and customs costs would change the total.
    Please let us know the next steps and maybe we can be of help?
  4. Bernie Garrett
    Vancouver Canada
    2001 Prius
    Thanks for the quick replies! You folks are great!
    More Info:
    Ok its a 2001 Prius with 102,000Kilometers on the clock.
    It came up with 12 error messages and the Toyota dealer said they had not seen anything like it. They then replaced the main battery (as it was under warrenty) and got lef with 2 error messages which they say indicate a Transmission failure.
    They are: P3000 and P3009
    I am not really sure they know exactly what the problem is as they say they are getting their info from Toyota Canada, and suggest it is a short in the Transaxle assembly.
    Any advice, or ideas on possible sources for used parts much appreciated. The car has been regularly serviced as per the schedule and seems to drive fine.
    Cheers
    Bernie
  5. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    P3000 is "HV Battery Malfunction" and P3009 is "High Voltage Leak Detected". They probably suspect a short in one of the electric motors, which is why they want to replace the transaxle. There's some discussion of it on this page.
  6. Bernie Garrett
    Vancouver Canada
    2001 Prius
    I have found one for $750 and 47,000 miles, with a one year guarantee. So I guess my options are to go for that and hope I don't get a recurrent failure, or shell out for a new unit and get my local transmission shop to replace it.
    Regards
    Bernie
  7. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Bernie,
    Depending on your situation perhaps getting a $750 replacement installed (don't know how much the service will cost) would make sense...then before the year is up selling or trading the car in with the intention of getting a new/newer one? That way you could defer a potentially larger financial committment for a year without substantial risk. (And who knows, within a year somebody might rear end you and total the car anyway, or you might make a mistake and total your vehicle in relatively minor collision.)
    You might even pursue what the dealer might be willing to do in a trade if you wouldn't mind getting a new/newer Prius. The market has softened quite a bit in the U.S. so perhaps you could get a decent deal in Canada. I've never done a trade in as a I prefer a simpler deal. However, you could first work out at another dealer what sort of price you could get on the model you want first (with no trade in the mix) so that you would know precisely how much your current dealer would give you in trade value. Obviously the dealer won't spend nearly as much on repair of your old vehicle for resale as what they would charge you. They will get salvage parts cheap, and they have no mark up on the labor.
    Beware of salvaged Toyota parts though. I just got burned on a salvaged Tundra rear end that supposedly had a year warranty. (If you are thinking of buying or servicing a Toyota in Albany, Georgia get ready to be ripped off.) They don't call 'em stealerships for nothing!
  8. Patrick Wong
    18,200
    6,471
    Hi Bernie,
    alanh provided a great link to the Art's Automotive website. This explains how the tech used a megger (a high voltage ohmmeter) to narrow down the problem, since P3009 can be caused by any component carrying high voltage, including the traction battery, the traction battery ECU, the main battery cables, the inverter, and the transaxle. Did your dealer tech perform a similar troubleshooting process to determine that the transaxle had failed (and not some other component)?
    Considering that your two remaining codes are P3000 and P3009, it seems possible to me that the traction battery ECU is the culprit (since the traction battery itself was just replaced.) That ECU should be covered under warranty.
    Since your car only has 102K km (or ~60K miles), is it possible that Toyota Canada might give you a break on the repair cost if in fact the transaxle definitely failed?
    Your first post says the car "runs". Do you notice any driveability issues or reduced mpg? What warning lights are on?
  9. Bernie Garrett
    Vancouver Canada
    2001 Prius
    Hi folks,
    Update. We ordered a used transmission from a breaker with 37k on it and hopefully it should arrive next week. However, today the warning lights went off!! This is very wierd and I am not sure if I should be happy as the Transaxle does not seem to need immediate replacement, or sad as I have spent $900 on a reoplacement unit!
    Maybe it is the cold weather here or something (-7 celcius) affecting it and it will return when it heats up. It seems to have driven Ok throughout this episode. :eek:
    Cheers
    Bernie
  10. Patrick Wong
    18,200
    6,471
    Hi Bernie,
    If the fault is intermittent, this is evidence that the transaxle may well be OK. If one of the electric motors had a wiring insulation fault resulting in DTC P3009 then I would expect the failure to be solid, not come & go.
    The fact that you indicate the car is driving "OK" even when warning lights are on may be further evidence that the transaxle is not the problem. Usually when the transaxle is bad, unusual drivetrain noises are produced and driveability is impaired.
    Before you expend the substantial labor $s associated with replacing the transaxle I urge you to have the diagnostic process performed (as demonstrated by the Art's Automotive website) to ensure that indeed the transaxle is the failed component.
  11. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    yeah same with that customer i dealt with, ( i was going to think it was you, but my customer had over 300,000 km on it).
    The car showed the same symptoms as yours, cold the codes go away, but as soon as the transaxle heats up something in there is not agreeing with the rest of the car...
    900 is a bargain compared to the 4500 i quoted a month back.
    He experienced extreme lack of power, when he got the warning lights, my guess is that the transaxle is limiting power to prevent some sort of further damage? So when your car's warning lights go off, can you still drive it normally? The only way he made the codes go away was to disconnect the ground portion of the 12 volt battery, but eventually the code will come back.
  12. Bernie Garrett
    Vancouver Canada
    2001 Prius
    Sounds like a good plan. I'll ask the transmission shop to run throught those tests for me.
    The lights perviously showing were the Red Triangle and in the bank of three warning symbols on the screen the one on the far right.
    Cheers
    Bernie​
  13. bwilson4web
    15,511
    When MG2 begins to fail, a common fault is one or more stator windings begins to short and burn up. This causes:
    • direct rotor coupling - so as the car moves, the MG2 rotor works like a generator, providing power that further heats the stator. This is often reported as a speed following 'rumble' or 'vibration.'
    • MG2 over temperature - the extra energy heats MG2. We've seen reports of over 150 C, we're talking very, very hot
    If the temperatures are cold enough, the transaxle heating won't be evident for short trips. However, the problem only gets worse.
    You may get a clue by changing the transaxle oil. Regardless, please have a dry, 0.5 liter bottle to capture an oil sample. I'm especially interested in your report of what it looks and smells like.
  14. Bernie Garrett
    Vancouver Canada
    2001 Prius
    Hi folks,
    Thought I'd update the group on the final outcome. After lots of hassle and a month off tghe road we eventually got this sorted with a Transaxle assembly for $900 from XVipers.com, with a reported milage of 37,000. They were actually OK to deal with, and the item arrived as described, and well packed in a crate.
    We tried to get our local Transmission shop to fit it but their shop staff refused on the basis of fear of electrocution, good grief! The only place who would fit it here in Vancouver were the Toyota dealers. They did the job in Richmond for just over $1,800 which also included a wheel bearing replacement. All in with taxes it cost $3k rather than $6K quoted by Toyota for a new transaxle. Toyota were very reluctant to fit the used part, and tried to push us into a new car. They were also very clear they offered no guarantee on anything, period.
    Overall, not a great experience on a 7 year old average milage car maintained as per maintenance schedule. Hope the newer models are better, as otherwise the gas & environmental advantages are gone with the increased maintenance costs/and parts obsolescence. Hopefully, our experience was a rarity.
    The car is running fine now, but I intend to replace the Transaxle fluid every 10,000K from now on as cheap insurance.
    Bernie:(
  15. Patrick Wong
    18,200
    6,471
    Hi Bernie,
    Thanks for the update. I am wondering whether its reasonable for you to disassemble the failed transaxle to see what it looks like inside? In particular, can you find burnt stator windings or other physical evidence of the failure? If so it would be great if you could post some photos!
    If you change the transaxle fluid at 30K mile intervals, using the correct Toyota ATF T-IV, that should be sufficient. Its also important to remove the drain pan and clean the metal debris off the pan bottom and the rectangular magnet.
    Good luck with your salvage transaxle, hope that it provides long service to you.
  16. Bernie Garrett
    Vancouver Canada
    2001 Prius
    sorry,
    Toyota junked it, thanks for the ATF tip! :)
    Bernie
  17. Patrick Wong
    18,200
    6,471
    OK, thanks for letting us know that the failed transaxle is no longer accessible to you.
    Regarding your observation above, the Toyota repair manual suggests removing the orange safety switch located at the traction battery, then allowing a couple of minutes to ensure that the inverter capacitors have discharged. When the inverter covers are removed, a voltmeter should be used to ensure that there's no high voltage present on the wires leading to the MGs. Its reasonable for untrained staff to be concerned about shock hazard, but it is easy to deal with this if you know the service procedure.
  18. Bernie Garrett
    Vancouver Canada
    2001 Prius
    Ys I told them that, but they still refused. Said someone in the US had been electrocuted. Nonsense I know, but they would not work on the car!
    Bernie
  19. tochatihu
    9,045
    3,528
    2001 Prius
    Glad to hear that you have a replacement transaxle installed Bernie. Since the history of that transaxle is not known, now (or soon) would be a good time to get a new transaxle gasket and the replacement fluid, and make the pan clean inside. If you find that it is already clean so much the better, but if there are metal fragments inside you want them gone.
  20. Patrick Wong
    18,200
    6,471
    Would it be too much to hope that the dealer's tech did this cleaning prior to filling the transaxle with ATF?
